Leak Problem - Event Date: 20 Sep 2017 |
Post Reply | Page <1234> |
Calendar Event: Leak Problem Posted: 25 Sep 2017 at 5:46pm |
Our 2011 Pod is one of the first year the spoiler was installed at the factory. It is parked outside in our Wisconsin winters and we have had no leak problems with it.
Tibof
Senior Member Joined: 19 Sep 2017 Location: North Idaho Online Status: Offline Posts: 115 |
Posted: 25 Sep 2017 at 6:05pm |
That's encouraging. I am glad that you don't have the problem and hope that most others don't either. BTW, have you resealed things, especially the spoiler? In any case, our Pod has a factory installed spoiler, and I am not impressed. It corresponds to the warpage that others have described. This is not warpage of the entire spoiler but "warpage" on the vertical sides where the spoiler pulls away from the roof. On mine, the gap couldn't be seen until I started to pry up the caulk. It then became apparent that the caulk only seemed to be in place when actually it was not sticking to the roof. Removing it showed a large gap above and below the middle screw. I attempted to add another screw just between the bottom and the mid point screw to pull the spoiler down snug to the roof. But there is no framing for it to bite into.
2015 Pod Hood River Edition
2012 Tacoma Crew Cab 4 Liter |
fwunder
Posted: 25 Sep 2017 at 7:17pm |
I'm just guessing that some folk's spoiler leaking problem may be due to a couple of different things.
One would be sealing the spoiler all the way around. Seems silly to me to caulk along the bottom of the spoiler. Let it weep and seal the top and sides as best you can. The other may be mistaking rear window leak or condensation. It's really pretty amazing how much condensation can form on rear window and look like a leak! Again, the rear window caulking should be concentrated on top and sides. Gravity works! Sometimes, I think we create problems where none existed. Just my 2 pennies on the subject. fred
Posted: 25 Sep 2017 at 9:49pm |
When I was at the factory to pick up our 179 after repair, I asked about it. I was told that the spoiler definitely makes a difference as the turbulence before spoilers were installed could result in loss of the spare tire cover. I don't have the pre/post spoiler experience to verify this but perhaps someone who has experienced with both configurations can address that. |
marwayne
Posted: 25 Sep 2017 at 11:08pm |
Subzilla
Senior Member Joined: 23 Jan 2017 Location: Concord, NC Online Status: Offline Posts: 302 |
Posted: 26 Sep 2017 at 7:32am |
Glueguy's post on the Airtabs intrigues me. Anyone here tried these?
Mark
Tibof
Posted: 26 Sep 2017 at 1:43pm |
The factory caulks or attempts to caulk the spoiler all the way around. But when I sealed ours with Eternabond, I applied it only to the top and sides. As for windows, our leak was definitely not the window, though windows can leak. The proper set for a window is butyl tape all the way around. If done correctly, the window should be leak free "forever." That would be the correct caulk for the spoiler, too, if the spoiler could be uniformly snugged down to the roof. But it can't be.
rda54
Senior Member Joined: 18 Nov 2016 Location: Minnesota Online Status: Offline Posts: 106 |
Posted: 20 Oct 2017 at 7:50pm |
Th a is to this forum I think I saved my rpod. We just washed and waxed our 178 and looked at the back spoiled and there was a gap in the caulking so I ordered the tape that others had talked about on the forum and put it on today. After putting it on I was getting it ready to park for the winter and there was wasted coming out of the back of the camper. I hope it isn't any thing to serious.
Ronald & Lonna
2014 178 2016 Chevy 1500 |
rda54
Posted: 20 Oct 2017 at 7:53pm |
I this is really bad sleep check. Spoiler and water coming out of the back
Ronald & Lonna
JillV
Newbie Joined: 02 Jul 2016 Location: Oak Harbor, WA Online Status: Offline Posts: 7 |
Posted: 21 Oct 2017 at 1:15pm |
Weve got two Damp Rid desiccants in our 179, both there for several weeks and both BONE DRY, yet water pooled on the kitchen counter behind our stove. Dry in the cupboard below and walls feel dry. Why aren’t the DampRids working? We’ve never had them not work before.
