  New Posts New Posts RSS Feed: Inverter and tv
Topic ClosedInverter and tv - Event Date: 07 Sep 2017
Mikefitz View Drop Down
Direct Link To This Post Calendar Event: Inverter and tv
    Posted: 07 Sep 2017 at 2:57pm
I have an rpod 179. I'm not good with electricity. It has the standard Jensen tv and stereo combination. The tv is 110 volt. I assume that the stereo is 12 volt. I'm not sure if the external antenna is 110 v or 12 v. My question is if I get a inverter for the tv can I watch dvd's? On that same thought, with an inverter on the tv, can I watch cable tv? I appreciate all of the help I can get.
TheBum View Drop Down
Direct Link To This Post Posted: 07 Sep 2017 at 5:04pm
Yes. A number of us have added inverters for the TV and other things. The factory TV only draws about 17W, so almost any inverter will work. The antenna booster and stereo are 12V. Cable TV will work too; you just have to turn off the antenna booster and plug the cable into the Pod.
DavMar View Drop Down
Direct Link To This Post Posted: 07 Sep 2017 at 5:22pm
Mike, first thing is your antenna has NO voltage applied to it either AC (alternating current) or DC (direct current). The antenna receives an RF (radio frequency) signal and sends it to your television tuner circuit the same holds for your Pod AM/FM radio. For your own reference the home you live in uses alternating current AC voltage. Your Pod inverts a DC current from your battery to AC current when your not using shore power (campground electricity) to run appliances that use only AC. A inverter converts DC current to an AC current where as an converter does the opposite, I know it can be confusing. I'm not sure if your radio/stereo is powered by a DC voltage or an AC voltage but it doesn't really matter. You don't need an inverter to run a dvd/blue ray player if your running your Pod on just battery but you will need to be aware that you have enough DC current (amps) from your battery to run the player and everything else. As for cable TV, unless your having to plug in a converter box into an AC plug in your Pod you don't need to worry about it.
I hope I haven't totally confused you? Maybe someone else here on the forum can explain it better then I.
wonder dog.
2017 Rpod 180
2016 Toyota Tacoma SR5 4x4
Lexington, NC
Tars Tarkas View Drop Down
Online Status: Online
Direct Link To This Post Posted: 07 Sep 2017 at 6:43pm
Actually, the antenna does have a 12v amplifier that can be turned off or on.
Direct Link To This Post Posted: 07 Sep 2017 at 7:01pm
That's what I thought. It's a power amp that runs 12V over the coax to the companion on the antenna.
Direct Link To This Post Posted: 08 Sep 2017 at 1:34pm
Originally posted by GlueGuy
Actually, the antenna does have a 12v amplifier that can be turned off or on.TT
No, it just boosts the signal coming over the coax. The antenna still outputs unamplified RF.
mloerzel View Drop Down
Direct Link To This Post Posted: 08 Sep 2017 at 9:46pm
I use this one, because it's Pure Sine Wave (better for sensitive electronics). I installed a 12v Outlet next to the fuse box.
Life is Too Serious to be taken Seriously
mjlrpod View Drop Down
Direct Link To This Post Posted: 10 Sep 2017 at 9:55am
Call it what you will, this much is for sure.
1. There is an on and off switch for the antennae booster.
2. Everything comes in better when it is turned on.
3. If you leave the antennae booster on when you disconnect from shore power, your battery will be dead fairly quickly.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 10 Sep 2017 at 10:09am
Good point. Who cares what is and isn't powered. It consumes power.
eye95 View Drop Down
Direct Link To This Post Posted: 10 Sep 2017 at 3:35pm
Not everything comes in better when boosted.
I have a booster on my antenna at home. It is attached to a plug that I can turn on or off from my iPad. Sometimes it has to be turned off to receive some channels.
<0>
2017 178 The "eye-Pod"
2011 Nissan Titan
