Ultrabreeze cover installation - Event Date: 06 Aug 2017 |
tabrods
Newbie Joined: 12 Aug 2016 Location: Montana Online Status: Offline Posts: 13 |
Calendar Event: Ultrabreeze cover installation Posted: 06 Aug 2017 at 2:44pm |
Hi everyone,
Got a question about installing the Ultrabreeze vent cover. according to the paperwork I should have a Fantastic fan and this should fit. None of the installation videos I've looked at show the two posts on each side that my fan has. Do I need a different cover or will this one work? Thanks, TomH
Posted: 06 Aug 2017 at 7:44pm |
When we bought our RP-179, it had a Fantastic Fan. When we went to pick it up at the factory where it was repaired from our accident last December, it had the MaxxAir fan. I had a Fantastic Fan Ultrabreeze cover which I had removed before it went to the factory. I was in the same situation. The Ultrabreeze cover won't fit unless it is modified. The cover that fits is the MaxxAir Fanmate. It has slots for the posts in your picture.
What I did was take a Dremel tool and cut slots to allow the Ultrabreeze cover to slide over the posts. I then bought clips to lock it in place. I was afraid the wind would rip it off as we went down the road. However, it has stayed on through our most recent trip of over 3,000 miles with no problem. When it finally does break, I will get the MaxxAir Fanmate cover. By the way, check the sealant at the corner at the bottom left. It looks like there might be a crack there that might allow water through. If so, clean it with denatured alcohol and add more Dicor self-leveling lap sealant to fill the crack. It might just be the angle, but it would be good to check. |
tabrods
Posted: 06 Aug 2017 at 8:02pm |
Thanks Stephan,
I thought it something like that. FR seems to have a habit of randomly switching components with no rhyme or reason. I appreciate the help. Spotted that corner and it's on my short list of things to do... Tom
Posted: 07 Aug 2017 at 11:15am |
Hello Tom,
You're welcome. There is a rhyme or reason to FR switching components. The MaxxAir vent is an improvement over the Fantastic Fan. For one thing, it has the ability to lock the lid in position so that one can leave it open while going down the road and it will stay in that position. The Fantastic Fan lid would vibrate and end up closed. The MaxxAir fan is also 4 speed instead of 3 speed. The final point is that it is extremely simple to add a cover. Just place it over the posts and insert the clips. That means no more drilling holes or installing mounting brackets. The other reason might be that they were able to get a better price per unit with the MaxxAir this time around. |
Posted: 07 Aug 2017 at 2:58pm |
The new camper has a clamped in FF, no screws. I bought a cover for an FF before I realized this. After thinking about it for a while and doing some math, I conclude that at 88mph, the wind pressure on the front of the cover is less then 20 pounds. So.. I am going to clean the roof really well, and tape it in place with eternabond tape. No screws. |
tabrods
Posted: 07 Aug 2017 at 8:05pm |
Thanks everyone for the helpful replies.
Tom |
