lippert Axels and Grease |
jimqbaum
Newbie Joined: 11 Jan 2016 Location: Virginia Online Status: Offline Posts: 39 |
Topic: lippert Axels and Grease Posted: 30 Jul 2017 at 3:00pm |
Found lots of videos on Dexter Easy Lube axles and how to lube, but I have the Lippert axle.
The grease access cover and all look the same. Anyone know if you can lube them the same as Dexter Easy Lube. The manufacture site does not make reference of this procedure. Jim |
Have A Blessed Day
Pod 171 Ram Hemi tow truck. Got rid of the Jeep Wrangler. It was puny and girly |
kymooses
Posted: 30 Jul 2017 at 7:36pm |
You're good to go, they work exactly the same.
jimqbaum
Posted: 30 Jul 2017 at 7:44pm |
Thanks,
I sort of gleaned after quite some time searching that the procedure was the same. I would be really swell if Lippert had a more informative web site. Jim |
Have A Blessed Day
Danielw1
Senior Member Joined: 01 Apr 2017 Location: Oregon Online Status: Offline Posts: 115 |
Posted: 30 Jul 2017 at 9:22pm |
Just don't overgrease or you'll blow the seals out !, I think a once a year repack is better than ever greasing
Posted: 30 Jul 2017 at 9:43pm |
With the Lippert and Dexter axles, one can't overgrease if doing it properly. The excess grease is forced out the front and is then wiped away before putting the rubber plug back. The proper way is to rotate the wheel while pumping grease in. That helps distribute the fresh grease through the bearings. I just did this today with my Lippert axle.
TheBum
Posted: 31 Jul 2017 at 12:24pm |
Is there any special fitting needed on the grease gun? I'm about to embark on regreasing the axle on our 179 before a trip to Colorado in a few weeks.
jimqbaum
Posted: 31 Jul 2017 at 1:08pm |
Update:
I greased the Lippert axle as per instruction on post here and what took a long time to get out of the worthless Lippert site, and successfully greased the axle. Spun tire and pumped out old grease through the front by adding new grease via gun. This took a long time. Wife unit spun tire while I pumped grease in. Thanks all for your input! |
Have A Blessed Day
Posted: 31 Jul 2017 at 3:22pm |
No. It is a standard Zerk fitting so any old grease gun will work. Use a good quality grease and you should be okay. |
