  New Posts New Posts RSS Feed: Keyless entry programming for 2014 r pod 177
Topic ClosedKeyless entry programming for 2014 r pod 177
jhpa View Drop Down
Direct Link To This Post Topic: Keyless entry programming for 2014 r pod 177
    Posted: 10 Jul 2017 at 8:41pm
I am hoping someone on the forum can help me figure out how to program the keyless entry pad on a 2014 r pod 177. First trip out in it and I locked the key inside! fortunately the window was open and I was able to slide the screen over and just barely reach the key. Hoping to get the key pad working so that doesn't happen againSmile
GlibGuy View Drop Down
Direct Link To This Post Posted: 11 Jul 2017 at 5:42am
Mine is a "Bauer Products" and they emailed me a sheet of instructions.  If yours is a BP, you can contact them: telephone (616) 245 - 4540 or email info@bauerproducts.com
MICK
devro View Drop Down
Direct Link To This Post Posted: 11 Jul 2017 at 6:03am
The instructions on how to set a keyless code were on the inside of the battery cover on my 2014 178.
However, mine will lock but will not unlock with the door closed.
With the door opened it will lock and unlock with the code, but if I shut the door it will not unlock.
I figure the bolt is hanging up on something and haven't had the time to figure it out and fix it.
Better keep a key hidden somewhere close!
JIM
Direct Link To This Post Posted: 11 Jul 2017 at 3:53pm
Hopefully you have a pair of keys to go with it, we won one of those last year at the ERU in Traverse City, Michigan.  Took about 10 minutes to install and as others have already stated, the instructions are on the inside of the battery cover.  I did notice that if it were working erratically, the batteries were probably to blame, changed them out for a fresh set, no more problems.
Direct Link To This Post Posted: 11 Jul 2017 at 4:06pm
I put in new batteries.  But maybe one or two of the new ones are bad?
I'll try new batteries and see if that helps.
Thanks
JIM
jhpa View Drop Down
Direct Link To This Post Posted: 13 Jul 2017 at 6:22pm
Thank so much to everyone for the responses! We are planning on figuring this out this weekend.
mcarter View Drop Down
Direct Link To This Post Posted: 13 Jul 2017 at 6:25pm
Also when you winterize, remove the batteries. Put in fresh set at next camping season.
