  New Posts New Posts RSS Feed: Hot water tank
Topic ClosedHot water tank - Event Date: 31 May 2017
Direct Link To This Post Calendar Event: Hot water tank
    Posted: 16 Jun 2017 at 7:55pm
Hey WillyBob,
If not on a 110 power source the heater can be propane heated, that's the switch not in your converter. If on 110 the CBs you need are the one in the converter and the one inside the water heater compartment. Just make sure you have water in the heater. If the fresh water tank is full, use the water pump, otherwise put city water on.
Direct Link To This Post Posted: 16 Jun 2017 at 7:59pm
Yes, as long as you have confirmed the bypass valve doesn't bypass the water heater, make sense?
Direct Link To This Post Posted: 16 Jun 2017 at 8:01pm
Originally posted by WillyBob
Oh, and how do you know the hot tank is full? I turned the pump on and opened the hot faucet in the sink and in the shower and eventually the pump shut off.  Tank full then?
That works. You can also open the cover outside and use the lever on the pressure relief valve to vent any air and make sure it is full. If you do this, it should be before you turn the heat source on so you don't scald yourself.
We all were new at this once. You will learn as you go. The more you use things, the more comfortable you will be doing so.
WillyBob View Drop Down
Direct Link To This Post Posted: 21 Jun 2017 at 9:55am
What do you mean by CBs?  One in the converter and one in the water heater?  Embarrassed
JivinWilly
Direct Link To This Post Posted: 21 Jun 2017 at 8:37pm
CB=circuit breaker
Direct Link To This Post Posted: 21 Jun 2017 at 11:15pm
About this site...how does one post a new question to the forum?  I can't find anything like "post a topic" or "post a new?".  I only see how to post a reply, so how to start another discussion.  I have many questions about our rpod.
JivinWilly
Direct Link To This Post Posted: 21 Jun 2017 at 11:27pm
Edited to add: Pick a forum (there are many like Podmods, Maintenance, Tips and Tricks) and then:
