Page <1 3456> |
podwerkz ![]() Senior Member ![]() ![]() Joined: 11 Mar 2019 Location: Texas Online Status: Offline Posts: 966 |
![]() Posted: 08 Apr 2019 at 11:38am |
Here is a link to the pictures of the interior of the dometic fridge 'eyebrow', with the battery compartment and the header that I would assume the battery holder will plug into. Until I dig into it further, I wont know if the pins are marked for polarity. (I dont know if this link will work) Also, I performed a check on the current draw to the electronics of just the fridge when running on propane: 57 milliamps. Pretty low. I would assume that number will be even lower on 8 AA batteries, since the manual says the fridge goes into power saving mode when on these batteries. There is no customer service number on the Dometic webpage that I could find, only an email form. If I get to the point where all my other mods are done and I want to persue this, I will make more efforts in that direction. |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6434 |
Be careful about using just any battery holder for this. The way the picture is, it is possible that this is only supplying 6V to the refrigerator given that the polarity of the batteries on one side of the case are both positive toward one end and on the other side of the case, they are negative toward the same end. You would really need to verify the voltage before you plug anything in.
DavMar ![]() Senior Member ![]() ![]() Joined: 04 Aug 2017 Location: Lexington, NC Online Status: Offline Posts: 592 |
Well that clears up allot podwerkz, it does seem your refrigerator has battery backup for the control board, lucky you! Just call them at: Dometic Retail Customer Service 1-800-544-4881 Opt.2, Opt.2 You can order the battery holder direct and receive any additional instructions you may need. Fred, the reason why you may want to have this battery backup to the control board is really simple. Lets suppose your hooked up to shore power and unbeknown to you the converter is dead. So you go on your happy way camping and the whole time all DC systems, such as the control board for your refrigerator, is slowly drawing down power from your camper battery. Until out of the blue and much to your surprise it drains so much power that the control board dies then guess what? Yep, no refrigerator, the gas will not ignite and all controls to it go dead. Unfortunately for me I found this out the hard way and even more unfortunate I found out that FR put in the bottom line Dometic refrigerator that doesn't even have the option for this control board. Luckily for me when it happened I also carry a dumb 6/12V battery charger so I was able to clip its leads onto the camper battery and all was good so we were able to continue our trip. |
Good point.
Thanks for the number DavMar. I will call them soon.
One thing I thought of: Inside the lower fridge outside service vent, are the hookups for 12v electronic, and 12v heater. They are clearly marked. I'm now referring to the 12v electronic supply, NOT the 12v heater supply. I measured the 57 ma current at that point. I see there is ample room under there for a small deep cycle sealed lead acid battery. One could wire up a switch or connector to feed the control circuits with that small SLA battery, and install a small solar panel and controller to keep that battery charged. Hmmm....the 'wheels' are turning!
Just as a note.. with dual T-105's installed we routinely went 10 days off grid, no battery switching or worries.The heater fan was the one and only thing that could shorten our stay without a recharge. How long do you hope to stay off grid?
I was going by the fact that the OP stated he had leads and a connector for the battery box...
Yes, trust me on this: I will NOT be randomly applying 6 or 12 volts to any of these pins on an expensive, brand new fridge. These electronic gizmos always seem to work better if you dont let the magic smoke out. ![]() |
Letting out the magic smoke in things electronic, Podwerkz, thanks for explanation. Finally, someone has given me a description of electronics and their function that makes perfect sense. I feel so much better about my constant refrain - go sacrifice a chicken when electronics are not working. Maybe the smoke from the Webber filters into the electronic widget adding to the volume of magic smoke inside or replacing some that has escaped. Now this is an example why this forum is so valuable to Pod owners.
Page <1 3456> |
