Page <1234> |
mjlrpod ![]() Senior Member ![]() ![]() Joined: 27 Sep 2016 Location: Massachusetts Online Status: Offline Posts: 1221 |
![]() Posted: 08 Aug 2017 at 12:58pm |
Great updates stephen. I stayed about an hour due south of emerald, just barely in massachucetts, clarksburg state park. It was really nice, but, not real R.V. friendly. one way , single lane roads and trees 1 foot off both sides. Not your easy back in sites.
2017.5 Rp-172
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6417 |
It is a combination. The valences support but I also used the heavy-duty Command Strips (the ones for picture frames that interlock so they can be removed/replaced). They also help support the shelf brackets I made. I am thinking of making it more permanent by using anchors to mount the brackets though. Although we have had no problems with the valences, over time, the weight bouncing on them may cause problems. The advantage of the 179 is that the bed and shelf are on the hitch end, which is the smoothest-riding end of the R-Pod. The kitchen end gets bounced around much more, being at the other end of the lever from the fulcrum (hitch).
Kup-Pod ![]() Senior Member ![]() ![]() Joined: 08 Jun 2017 Location: Guelph, Ontario Online Status: Offline Posts: 153 |
Hi Stephen,
Thanks for the insights, it helps for me to figure out if I'm working in the right direction. We just came back from our first full vacation trip with our new 178; 2 weeks at MacGregor Provincial Park on the shores of Lake Huron. The provincial parks in Ontario are very good, the only thing they are missing is water hook up, so you have to use the fresh water tank / pump option. It was our first experience camping with the Rpod and we were very impressed (a huge leap forward from the 20 year old tent trailer!). We also have the Thule awning and are very glad we ended up with that over the R-dome, the awning is very easy to set up and I was impressed how stable it is. We intentionally held off on all mods we want to do until we have a few trips under our belt, but I really like a few of your suggestions... One question for you, with your shelf over the bed, did you anchor it to the walls or did you rely on the window valens to hold the weight? Thanks again for your input... Kasper
2017 RP-178
2021 F150 5.0l "Lead me on a level path" |
Here is an addendum: I got the form and filed a warranty claim with WFCO. The faulty converter has been replaced. However, it is now a spare as I had ordered a replacement and installed it so we could finish our trip. I'm debating on whether to keep it with us so it will be available if the current one should fail or to try to sell it to recoup at least part of the money I spent fixing it.
We did the shopping we needed to in preparation for the rest of the team's arrival. We also prepared dinner for them. We prepared a total of three dinners and one dessert for Wednesday's potluck at Washington Baptist Church. I made two maple cheesecakes in the 6 quart pressure cooker. Since each was small, I needed to make two to ensure there would be sufficient for everyone present to have some.
My replacement converter arrived with the team. I got it installed and turned the power on. It was wonderful to hear the fan start and see the batteries were charging again. Even though I had a charger connected, it was only a 15A charger with 3A float, which was insufficient to keep the dual 6V batteries charged, as it detected the power draws and determined (wrongly) that the batteries were "bad." With the new converter in place, the batteries were charged fully. The week at the Calef house and Waterbury Mission went quickly. The new awning performs well. I did do one stupid thing as I was packing up the Coleman grill-stove and propane tank. It looked as if there were some water in the propane hose, so I decided to swing it around to use centrifugal force to help expel the water. I was standing too close to the awning, and the Acme nut hit the top part of the awning's outer edge and dented it! ![]() We got hitched up after the last trip to Waterbury and set out for home. We got as far as Cobleskill, NY where we spent the night at a Walmart. I had hoped to get into Pennsylvania at least, but when the daylight was running out, that was my cue to stop. The next morning we set out and in spite of the GPS wanting to route us around the DC beltway, we stayed on I81. This time, we got as far as Winchester, VA where we stopped at a Walmart again. It had been quite warm during the day, but the evening cooled off enough so that we did not need the AC, just the vent fan plus the O2 Cool fan. By the way, we found a good buy on the O2 Cool fan at our local Staples. It runs on 9V (six D-Cell batteries) and has a 110V transformer. It had the same plug as the other fan we were using, so I plugged it in to one of our 12V outlets. It ran just fine but was a little louder. It still moved more air than the previous fan as the O2 Cool has 5 blades instead of the 3 blades of the previous fan. We left Winchester and finally arrived home Sunday afternoon about 5:00 p.m. We are in the process of unpacking and getting set for our next adventure. The next one will not involve the R-Pod, but will instead involve flying to Seattle for an Alaska cruise with my brother and sisters and their families. In many respects, I would rather drive to Seattle with the R-Pod for the cruise, but there are too many conflicting appointments for that to happen. That is it until our next adventure. |
We had an enjoyable time (but wet except for one day) at Emerald Lake. While we were there, we drove on over to the Vermont Country Store in Weston. We had our first maple cremee of this trip there and bought a few items that caught our eye. We could have spent a whole lot more as there were many things there not to be found elsewhere. It was a good way to spend a rainy morning. By the time we got back, the weather had dried out. We took the time to do some laundry on another rainy day. The one good day I had, I spent configuring a way to connect up the generator's 12V outlet to charge our batteries since the park does not have hookups (except for the camp host sites). The converter, which had shown some problems, but started working had again malfunctioned while we were in Oneonta. I had bought a battery charger, but figured the 12V output of the generator would be more effective than running the charger. In the meantime, I ordered a replacement WFCO converter and had it shipped to our pastor who would be coming up with the group. We conserved battery power and limped through our stay with no problems.
On Friday, we hitched up again and pulled to the Calef Retreat Center in Washington, Vermont. Along the way, we stopped at the King Arthur Flour store. We again spent more than I had intended, but found some useful items. We arrived at the Calef House and unhitched. The couple that runs the retreat center was not there, so I started to set up. I was going to plug in to a 15V outlet again this year when David pointed out a 30A RV outlet. Unfortunately, the trailer was a little too far from it, so I hiched up and moved the trailer over to be able to run the cord to the trailer from the outlet. It was worth the trouble to do so as a couple of the days were quite warm so I was able to run the AC. At night, I switched back to just the vent fan since the nights were quite cool. I ended up running the furnace a couple of mornings to take the chill off. |
Leo B ![]() podders Helping podders - pHp ![]() Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4518 |
Welcome to Vermont!!
The third leg of our trip was to pull from Oneonta, NY to Emerald Lake State Park in Vermont. The trip was uneventful. I remembered that approaching the border between New York and Vermont, gas stops could be sparse. I filled up near Troy. Given that the Frontier has a larger tank than the Escape, and given that my mileage is better now that I remember to keep the engine RPMs down, we were in no danger of running low.
Emerald Lake State Park is a beautiful place. Camping is boondocking as only the camp hosts have any sort of hookups. Since our converter is not functioning properly, we have been conserving our battery power. Today, I went to an automotive store and picked up some wiring and connectors to be able to use the Generac iX2000's 12V outlet to charge the batteries. I was able to get about an hour of charging before generator hours (8:00-10:00 a.m. and 4:00 to 6:00 p.m.) ended. Tomorrow, I will run the generator more to get more charge into the batteries, at least until we can get the converter replaced (part ordered, delivered, and will be brought by the group we are linking up with on Saturday). We arrived at Emerald Lake on Monday. That evening, it rained. Yesterday, it rained until the afternoon. My wife had been wanting to visit The Vermont Country Store so we went to the one in Weston. That was a 45 minute trip from the park. We purchased a few things and made our way back. Today was very nice. The temperatures were pleasant and there was sunshine. This will probably be the last of the nice weather we will have for our stay here. Tomorrow and Friday (the day we plan to leave) are expected to be rainy. I'm sitting outside, enjoying our last campfire of this stay. It is about perfect for doing S'Mores, but we don't have the ingredients. My wife wants to do laundry, so tomorrow's rain means we will not be wasting a beautiful day waiting for laundry to be done. A couple of more details about the park: The lake does have a swimming area and people bring kayaks and canoes. The park has lean-to style shelters which are a three-sided building. People use them for camping, with or without additional tents. The other sites are referred to as tent sites, even though there are a number of trailers, both hard side and pop-ups along with a truck camper or two. There aren't any of the big RV's up here. The road up to the camping area would be tricky for them to navigate anyway. The sites are spacious and uncrowded where we are staying. Some areas are more dense, but we are along a connecting road. Facilities are farther away, but it is very peaceful where we are. That's it for now. |
I have been delayed posting the second leg of our trip. We packed up and pulled out of my sister's driveway on a shorter trip across New York State. Our destination for this leg was Susquehanna Trail Campground. We had stayed there last year and found it was a convenient distance to the nursing home where my father-in-law is residing. We got there and were directed to a spot near where we stayed last year. The site backs up to Otego creek. The site is back-in with a gravel entrance and pad. These are larger gravel stones. While I was unhitching, the gravel allowed my Andersen leveler and BAL chock to shift. I hitched the trailer again in order to level again. Having done that, I went to plug in the AC power. I have a circuit analyzer inline with my power cord. When I plugged it in and flipped the breaker, I saw that the power pole had an open ground. I reported it to the management and then moved to a different site which meant hitching up again in order to move. At least I had not yet gotten fully set up.
Once moved, leveled, chocked, and stabilized, I was able to get the power connected. I got the slide-out cover and awning deployed just in time as the rain arrived shortly afterward. I really like the new awning that I bought and that was installed when our R-Pod went to the factory for repair. It is so easy to insert the crank and wind it out. The weather was not conducive to taking advantage of the pool. The water was a little too cold for my liking. had the day been warmer, it would have felt nice though. We had some good visits with my father-in-law and went over the mountains to my wife's home town to pick up some things from her brother. Until next time . . . . |
Safe travels!
Page <1234> |
