Page <1234> |
![]() Posted: 12 Apr 2018 at 9:20am |
Do an advanced search on "Post Images". Most of us use postimage.org. Once in post image. Select image size (800X600). Select removal time. Open pic source. Choose image. Go to "Hotlink for Forums". Click on Blue Folder icon. Indicates copied. Return to post - Control V, you can copy one image at a time.
onazip ![]() Groupie ![]() ![]() Joined: 04 Apr 2018 Location: albertville mn Online Status: Offline Posts: 43 |
2018 Tundra
2018 176t |
If the regulator is not built in, you just need the connecting hose. From the AUX connection on Pod to the regulator connection on grill.
how do i post a pic?
2018 Tundra
2018 176t |
actually, the regulator is not built in. it came with the grill but you have to screw it on every time you want to use the grill. I'll figure out how to get a picture on here.
2018 Tundra
2018 176t |
You can buy an adapter hose that will feed it straight from the 20 pound tank, using a splitter valve, OR, you can modify the grill to accept low pressure to run it from the Pod's low pressure port, if your Pod has one. Splitter Valve. You will then need a 20lb to 1lb adapter hose. Convert to low pressure. |
Are you talking about the AUX Propane Connection on the R-Pod? If so it is low pressure. You can't connect a grill with a built in regulator to the line, in other words you can't regulate twice. You have to modify grill connections to eliminate the regulator. CAMCO makes an adapter that allows you to run off your on board tank, by adding low pressure and high pressure ports in line with your present propane system, I use that as I don't have an AUX Propane connection.
Can the Coleman roadtrip grill be hooked up directly to the propane connection on the R-Pod? So we wouldn't have to use the small, disposable propane tanks.
2018 Tundra
2018 176t |
Leo B ![]() podders Helping podders - pHp ![]() Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4518 |
+1 for the Weber Q
Weber Q - BTW made in America.
Page <1234> |
