  New Posts New Posts RSS Feed: cotter pin
Topic Closedcotter pin
Direct Link To This Post Topic: cotter pin
    Posted: 29 Jul 2020 at 6:08pm
If you use a  bolt and nut be sure to get a nylock nut. If that nut works its way off and the bolt comes out bad things could happen. Star
EchoGale View Drop Down
Direct Link To This Post Posted: 29 Jul 2020 at 5:33pm
I like the bolt idea too and there is, I think, a tractor supply.  I think I have some good things to try now. Thanks a lot!
Julie
mcarter View Drop Down
Direct Link To This Post Posted: 29 Jul 2020 at 5:18pm
You have a Tractor Supply near you? They deal in heavy stuff.
lostagain View Drop Down
Direct Link To This Post Posted: 29 Jul 2020 at 5:06pm
How about a small bolt with a partially threaded shaft?
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Direct Link To This Post Posted: 29 Jul 2020 at 4:59pm
Oh! Offgrid. that's exactly what I need. thanks!
Julie
Direct Link To This Post Posted: 29 Jul 2020 at 4:56pm
Yes...did that. Went to ace. That's where I got the smaller one that I could handle to put on but, because it was smaller it bent. making it even harder to remove. I want something different, something I can use more easily.
Julie
Direct Link To This Post Posted: 29 Jul 2020 at 4:29pm
If your talking about the clip part of item 2 in the Anderson wdh manual maybe you could find a carabiner that would be the right size and diameter to replace it.
GlueGuy View Drop Down
Direct Link To This Post Posted: 29 Jul 2020 at 4:27pm
You can get those in various sizes at a place like Home Depot, or probably better, ACE hardware.
Direct Link To This Post Posted: 29 Jul 2020 at 4:05pm
I'm wondering if anyone knows of an alternative to a traditional cotter pin. My Andersen WDH requires one and its very hard for me to use. I end up trying to grip it with pliers or pound it our with my rubber mallet.  I've tried a smaller cotter pin but it bends making it just as hard to remove.
I'm thinking a straight pin with a lock on the end or something (there's something form Master but its too think to slide through the hole it needs to go into.)
Thanks!
Julie
