  New Posts New Posts RSS Feed: Westlake Tires
Topic ClosedWestlake Tires - Event Date: 17 Jul 2020 - 30 Aug 2020
Direct Link To This Post Calendar Event: Westlake Tires
    Posted: 18 Jul 2020 at 11:05am
If they are load range D tires, you should be okay. Even the Carlisle LR-D 14" tires I now have on my RP179 are made in China. I would prefer made in the USA, but the Carlisles are doing okay overall. I did replace one that was wearing in a way I did not like. It looks like somewhere along the way it lost the balance weight and had some flat spots on the tread where the tire was wearing very unevenly. The replacement Carlisle tire is balanced.
Direct Link To This Post Posted: 18 Jul 2020 at 11:12am
Originally posted by D-Pod
My ST235/75/R15 have a load range 2910# . It is a "D". Tires look good but always a concern about tires from China. Some tire "experts" suggest switching them out right away. Why take a chance.
That's certainly a personal choice you can make. For myself, I run Chinese 15 inch LRD's, keep them inflated properly, and am OK with it.
lostagain View Drop Down
Direct Link To This Post Posted: 18 Jul 2020 at 11:30am
Are there any data bases that compare tires built around the world?  We make assumptions about quality that aren't necessarily factually based, often due to underlying biases and prejudices and with little actual personal knowledge.  Some people say Chinese tires are generally sub-standard, but does the data support such a claim or is it simply anti-Chinese bias?
For myself, having been educated just enough in tire manufacturing when I defended some US tire companies, I prefer to stick to major brands, regardless of the location of manufacture for a specific tire.  The big brands have a vested interest in maintaining a reputation for quality that could be easily lost if they were to put their names on inferior products.  Though that is no guarantee of quality, it improves one's odds of getting tires that are safe and durable.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Direct Link To This Post Posted: 18 Jul 2020 at 1:55pm
Consumer reports and NHTSA rate vehicle tires but I haven't seem ratings anywhere for trailer tires.
mcarter View Drop Down
Direct Link To This Post Posted: 18 Jul 2020 at 5:50pm
+1.
frozebubba View Drop Down
Direct Link To This Post Posted: 26 Aug 2020 at 12:59pm
I have the 15", load range C, Westlake "snow" tires on my 2016 RP171 HRE.  They have a single load rating of 1985 lb at 50 psi stamped on the tires.  I had to get them balanced right off the bat and have pulled it at max gross weight (3200 lb; 400 lb of this on the tongue) for about 18,000 miles at frequently checked 50 psi cold with no flats or tire failures.   I usually drive at 65mph if road conditions allow.  However, the tires have developed an odd wear pattern.  When I run my hand over the tread it is noticeably rough feeling.  The outside blocks tend to be taller on the front of the block (10 32nd's vs 6 32nd's, passenger side) but taller on the rear of the blocks (driver side)!  It's hard to get a reliable tread depth measurement because none of the adjacent blocks, outside, center or off-center are the same depth. Given the roughness, they are wearing evenly on outside compared to the inside but the small individual off-center blocks tend to be shorter than anything else.  The wear pattern makes no sense to me.  Has anyone else seen this odd wear pattern or have a suggestion as to the possible cause?  Tire shops just scratch their heads when I show them.  I was just figuring they were poorly designed cheap tires.
Direct Link To This Post Posted: 26 Aug 2020 at 1:24pm
The wear looks to be what the Tire Rack blog is calling "heel-to-toe wear."
