  New Posts New Posts RSS Feed: RPOD 190 DeWinterizing
Topic ClosedRPOD 190 DeWinterizing
mjlrpod View Drop Down
Direct Link To This Post Topic: RPOD 190 DeWinterizing
    Posted: 30 Apr 2020 at 3:43pm
When winterized, the water heater should be bypassed. If you can find the access to the tank inside the camper, usually under a dinette, bed, or removable panel, there are usually 3 inline valves. the water into the tank should be turned in line with the hose going in, the out, inline with hose going out, and the center should be perpendicular to the hoses. You might need to find the fresh water pump and turn off the intake valve there also. There are you tube videos on everything else
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
PODNNJ View Drop Down
Direct Link To This Post Posted: 30 Apr 2020 at 2:13pm
Hello-
This will be my first time dewinterizing a 2019 190.... it was winterized by the dealer.
Do they by default closes the valves to the water heater? Also.. does anybody have a picture of the water heater valve setup on the 190's?
Thanks in advance
