  New Posts New Posts RSS Feed: Hot water heater question
Topic ClosedHot water heater question
GlueGuy View Drop Down
Direct Link To This Post Topic: Hot water heater question
    Posted: 26 Apr 2020 at 10:01am
Potato, potahto. We all know you are talking about spuds.
Direct Link To This Post Posted: 26 Apr 2020 at 11:44am
Water heater/hot water heater, who cares?  We all understand you won't have a nice hot shower if it doesn't work. Unhappy
crankster78 View Drop Down
Direct Link To This Post Posted: 27 Apr 2020 at 10:44am
Greetings:
I leave the water heater bypassed,(don't fill it)  and just use a kettle to heat the water I need on the stove.  I travel by myself, usually stay in parks.  I take a shower at park showers,  Otherwise, I take a sponge bath using less than a gallon.  The water in the kettle heats up faster than the water heater, and uses less water.  Just my way.
Crankster78  (soon to be 80)
Crankster 78 R-179 2015
Pod People View Drop Down
Direct Link To This Post Posted: 28 Apr 2020 at 8:02am
We do the same as Crankster-use  an electric water kettle when on shore power and propane stove when boondocking to heat our water. It's easy once you get used to it.
the water heater wastes a lot of water getting from the heater to the kitchen sink or shower and fills the grey tank unnecessarily.
Everyone has their own systems-do whatever works best for you
Vann
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 28 Apr 2020 at 8:59am
Ideally, I would like to put in a recirculating system to pre-heat the water in the pipes without wasting it or flushing it down the drain. The water heater is best used when one is at a campground/RV park with full hookups so that the shot of cold water does not fill the gray water tank, but instead goes direct to the sewage system. I think that will be a project I will tackle soon given that we won't be going anywhere in the near future.
Direct Link To This Post Posted: 28 Apr 2020 at 9:03am
I agree there is water waste using the water heater, first in waiting till you get warm water, then in fiddling with the temperature. I added an adjustable thermostat that keeps the hot water at just the right temp for our showers. We turn on the water heater once a day, wait half an hour or so, start washing dishes with the cool water in the lines, finish and rinse with hot water. Then take our “navy” showers and shut off the heater. Or you can run water into a pitcher and pour it back into the fresh tank later. Another way to solve the same boondocking problem, either will work.
lostagain View Drop Down
Direct Link To This Post Posted: 28 Apr 2020 at 10:54am
We save the water out of the tap while waiting for the hot water heater (Evil Smile) water to arrive at the faucet and use it for washing or rinsing stuff.  It's never been an issue that would justify a more complicated intervention for us.  The shower head on/off valve is designed to drizzle a bit and that keeps enough water tricking out to avoid needing to adjust the h/c mix if you don't dilly dally while soaping up.  For each of us, a shower with over a minute of water flowing would move into the Hollywood shower category.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
mjlrpod View Drop Down
Direct Link To This Post Posted: 28 Apr 2020 at 12:05pm
I stopped doing dishes in the camper a few years ago, and my grey tank is very manageable. Pretty much the only water that goes into the grey tank is from the "navy" showers, which we use as little water as possible. I use a water jug on the end of the picnic table, and a 5 gallon bucket catch basin. I wipe everything with a wet nap type wipe to degrease , then wash it under the water jug, and done. On longer stays, it might require a couple empties into the campground sink. It works for me
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 28 Apr 2020 at 3:17pm
Feel free to drizzle all the hot water you want that your poor hot water heater worked so hard making for you by heating the cold water it received directly from your unheated fresh water tank. Always having that perfect shower temperature, with no fiddling, now that's camping luxury. And all for less than $5 IIRC. Cheapest mod ever.  Big smile
Direct Link To This Post Posted: 28 Apr 2020 at 5:20pm
It works.  It's simple and it doesn't break.  The amount of trickle of water is less than a cup while quickly soaping up.  We're in and out really fast.
Sonoma 167RB
Our Pod 172
