  New Posts New Posts RSS Feed: Replace Batwing with Dish ANT
Topic ClosedReplace Batwing with Dish ANT
Direct Link To This Post Topic: Replace Batwing with Dish ANT
    Posted: 28 Oct 2019 at 8:41am
Looks good, glad it improved the reception.. The earlier Pods came with a omni-directional saucer style.. when the bat wing was introduced many new owners reported reception that seemed way less.. but we honestly only used ours a couple of times.. 3 years in with the Lance, and the antenna has never been turned on except the first weekend here to make sure it worked.. If we are in a park, with cable, we will usually tune that in, mostly to check the weather.
I know I have seen many big rigs over the years that appeared to be using one of the flat wire stick on antennas stuck to a drivers window or side window, rather then the crank up / directional on top..
GlueGuy View Drop Down
Direct Link To This Post Posted: 28 Oct 2019 at 9:52am
Originally posted by mcarter
Thanks, the day I changed antennas was within hours of tests with no weather change. The test showed an improvement with the Magnadyne. The King OmniPro is advertised at 50-60 miles, while the Magnadyne, rated at 35 is closer to 25 I think.
Don't go by "distance", look at the published gain for the antenna. In VHF/UHF bands a gain of 6 or 7 is as about as good as you can get in an omni. You can get higher gains, but really only with a very large directional antenna (which is really what the batwing is).
Many antenna sellers don't publish gain information, in which case, I would just look elsewhere. The other issue with many so-called omni antennas is that they aren't really omni-directional, but have high and low gain lobes. I've never seen an antenna seller publish the antenna gain plot, maybe because most consumers wouldn't know what they're looking at anyway.
Direct Link To This Post Posted: 28 Oct 2019 at 11:29am
   I prefer not to watch TV much when camping or at home but my wife does because she is disabled unable to do much walking. There is a Omni antenna that got my attention but not many reviews because it is fairly new, I found it on amazon.com its name is SKYBOXE UFO price $117 but not sure if it would be much better than the Magnadyne or the Omni Pro but am a little curious.
2014 Ram 1500 Quad cab
mcarter View Drop Down
Direct Link To This Post Posted: 28 Oct 2019 at 4:02pm
The Skyboxe to my knowledge is directional. There is some work and modifications that would be required to mount it on my Pod, and I'm not that fascinated by TV to do that. If I can't get OTA TV, I start going thru DVDs.
Direct Link To This Post Posted: 28 Oct 2019 at 7:45pm
The SKYBOXE UFO antenna claims "720°Dual-Omni-Directional". Ain't no such thing. The maximum direction for an omni antenna is 360°.
I would look at this with very skeptical eyes.
