  New Posts New Posts RSS Feed: 6000 fantastic miles
Topic Closed6000 fantastic miles
gpokluda View Drop Down
Direct Link To This Post Topic: 6000 fantastic miles
    Posted: 20 Oct 2019 at 2:21pm
Update: So I went with the Sumosprings over the airbag suspension. What a difference! I chose the blue Sumosprings which brought the back end of the truck about 1.5". They did stiffen the ride of the truck without load, but really do control the squat when I load the back with generators and other stuff. One thing I noticed immediately while towing was that the truck doest wallow when I go through dips.
Great suggestion. Thanks!
Direct Link To This Post Posted: 20 Oct 2019 at 3:47pm
I'm glad they worked out for you. They definitely make a difference for us as well. I recently had to take my RPod in for an axle change because of a broken weld (warranty repair). I had to remove the Hensley hitch because I knew that the shop where I took it would not have the ability to move the RPod around with the Hensley hitch installed. Even with jus the SumoSprings, I did not like the way it behaved. This week, the Hensley Cub will be going back on. In my case, having both the SumoSprings and a good WDH is the best combination.
