Topic: Investigating RVing Posted: 10 Oct 2018 at 4:20pm |
I would recommend a Class III hitch, of course there is more than that and many here can advise, you are in the best place to ask with this group. Best to start with success.
abqdan
Posted: 10 Oct 2018 at 2:20pm |
I'm afraid I didn't - but I do now! I've never towed anything - the vehicle came with the hitch, but I've only used it for a bike rack  All the different 'weights' on specs for trailers were confusing, and I asked at a dealership and they acted like I was a moron and shouldn't bother them with questions. Now I know I can't tow with this vehicle, I'll have to find one that can tow. So do I need a class 3 or something else to tow an RV like the Rpod?
abqdan
Posted: 10 Oct 2018 at 2:16pm |
Thanks! We don't have experience with towing anything, so I wasn't sure where to start - the information online is confusing (for me at least). A lot of experienced people assume you know things you don't, so advice I've received before wasn't helpful. Anyway, good to know that what I can't do. Now to figure out what I can!
Posted: 10 Oct 2018 at 1:01pm |
abqdan,
I'm sure you know this: Class II hitches are weight carrying (WC) hitches rated up to 3500 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 300 lbs. That would not safely tow a Pod.
Ben Herman
Posted: 10 Oct 2018 at 12:16pm |
Originally posted by abqdan
Hi everyone! We have long been tent campers, but age is creeping up, and we're beginning to get to the point where that all seems a little too rustic! We've looked at pop-ups, but since our aim is to investigate cooler regions of the country, something with cloth sides doesn't appeal.
The R-pod seems to us to be a great option, because we're only going to be using it infrequently, and we don't need much space. We'd also like to see if we can find a towable that our trusty Hyundai Santa Fe Limited can tow - it has a Class 2 hitch, a V6 engine, and according to the specs a 3500 pound towing capacity. I'm hoping to discover if anyone with the same vehicle has towed an R-pod.
Hi and welcome - you might try an search on this forum, this topic has come up many times and the consensus is that a vehicle with a capacity of 3500# is not up to the task of towing an Rpod. We started our adventures of trailering for the same reason as you did - tenting no longer cut it for our aging bodies. We initially towed with a vehicle with a V6 aqnd closer to 5,000# capacity and it still seemed underpowered. Keep in mind that by the time you load up a trailer with all of your gear, water, food, etc you add considerably to the gross weight. Not sure where you live or wish to travel (i'm in Colorado) so hill-climbing is another factor.
We traded in our vehicle for an older Lexus GX470 with a V8 and much higher towing capacity and its a much better experience all around.
Good luck with your search!
abqdan
Posted: 10 Oct 2018 at 11:20am |
