Batteries? |
Post Reply | Page <1234> |
Olddawgsrule
Senior Member Joined: 20 Sep 2017 Location: New Hampshire Online Status: Offline Posts: 1014 |
Topic: Batteries? Posted: 23 May 2018 at 1:07pm |
Keep checking http://www.aliexpress.com Best pricing I have found. Just by from the better suppliers! I find Littokala to be one of the good ones.
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6293 |
Posted: 23 May 2018 at 1:15pm |
That is not the type battery to which I was referring. The NexGen ones or equivalent are.
Olddawgsrule
Posted: 23 May 2018 at 1:22pm |
Search Ali for those then.. It's the site I was passing along.
Posted: 24 May 2018 at 12:55am |
Thanks. I'll check back from time to time to see if they drop to a point where I would feel comfortable purchasing them. Until then, I'll keep plugging away with my dual 6V flooded cell batteries.
SteveA
Groupie Joined: 19 Jul 2017 Location: Sandpoint Id Online Status: Offline Posts: 56 |
Posted: 24 May 2018 at 9:41am |
What battery set up you use may have a little to do with the age of your Pod. Newer Pods are all LED lighting inside and out which use very little battery power, this combined with the water pump and stereo are our major use the battery power in a '17 /2 179. We boondock much of the time, once stopped and setup the first thing I do is plug in a solar panel to keep the battery "topped off". With the fridge and water heater on propane (1 8gal propane tank upgrade), LED lighting, constant Sirius satellight radio playing and solar panel plugged in we have never had an issue with 1 large deep cycle rv battery. If we wish to run the tv, ac, microwave or elect water heater (once the propane water heating element failed) we start the Honda 2000i. Using this system, this is a very self contained unit.
2017 179 1/2
Olddawgsrule
Posted: 24 May 2018 at 4:15pm |
There you go! Smart usage! Knowing what you can and how is Oh so important! I'm running without a generator, also no AC or Microwave. TV is my Laptop. Music is internet or on a stick to my Oonz speaker. So far so good! Under 18amps (or 255 watts). Solar has kept up so far (130w panel). Fingers crossed it stays this way.. LOL
Tom A
Groupie Joined: 04 May 2018 Location: Evanston, IL Online Status: Offline Posts: 70 |
Posted: 24 May 2018 at 4:22pm |
Thanks to all for your input and enlightenment. As a newbe to trailer camping I am learning a lot here.
Now for a new thread on solar panels. Tom
2018 Sequoia--2018 RP 190
Guests
Guest Group |
Posted: 24 May 2018 at 4:39pm |
I use two 12v RV/Marine batteries wired in parallel. These are backed up by a generator for recharging. How long they last has a lot to do with the time of year, also. When temperatures fall, so does battery capacity. This is also when I use the furnace and it gobbles power. |
Tom A
Posted: 25 May 2018 at 6:10pm |
I was just advised not to leave my new 190 plugged into shore power because the stock inverters are not good enough and it will fry my battery.
Really?
Tars Tarkas
Posted: 25 May 2018 at 8:06pm |
It wasn't just R*Pods or Forest River, but there were apparently a lot of bad converters in the overall RV market a year or two ago and people had a lot of trouble with them. They quit working; I don't recall hearing about them frying batteries. My converter (and it's a converter, not an inverter) is nearly 10 years old and I keep my pod plugged in all the time when I'm home. Never had a problem. RPod converters generally have a good reputation and the charger is supposed to be a really good 3-stage charger. I'm curious where you heard that story.... TT |
FJ Cruiser |
