  New Posts New Posts RSS Feed: USB charger
Topic ClosedUSB charger
mcarter View Drop Down
Direct Link To This Post Topic: USB charger
    Posted: 11 May 2018 at 7:27pm
Yes, with wire ties you can put small screw in to hold to bottom, then I flex seal.
Direct Link To This Post Posted: 11 May 2018 at 8:47pm
You should have no issue running under the shower pan.
GlueGuy View Drop Down
Direct Link To This Post Posted: 11 May 2018 at 10:17pm
Originally posted by Ben Herman
Originally posted by mcarter
I ran under the floor and back into converter bay. I have a 178.
Did you put your wires inside flexible tubing to protect them? I've not done that before, but thinking that 14 gauge wire needs some protection from the elements....
Putting the wire into flex tubing would be a great idea if running the wires under the floor. 14 AWG might be a bit overkill for a USB charger, but it's not going to hurt anything.
