  New Posts New Posts RSS Feed: Solar panel
Topic ClosedSolar panel
Tars Tarkas View Drop Down
Direct Link To This Post Topic: Solar panel
    Posted: 30 May 2017 at 7:26pm
I just got a Renogy 100w suitcase and am pretty happy with it so far.  This is my first real experience with solar, so I can't rate it against anything else except for price.  You can get 100w from Renogy for a lot less than 80w from Zamp costs.  If your Pod has the Zamp hookup you can get an adapter or just bypass it and go straight to the battery.
TT
FJ Cruiser
GlueGuy View Drop Down
Direct Link To This Post Posted: 30 May 2017 at 4:20pm
The panels almost don't matter. Whatever you get needs to feed a 12V system in the end.
More important is the charge controller you get that will connect between the panel(s) and your 12V R-pod.
My personal opinion is to get a panel (or panels) that provide whatever power (in watts) that you need. If the panel(s) provide too much voltage, get a MPPT controller to adapt it to your 12V batteries. If you get a low voltage panel (or panels), you can use a PWM controller. My personal preference is MPPT since they can wring out more power for a given situation.
texman View Drop Down
Direct Link To This Post Posted: 30 May 2017 at 2:59pm
I have a zamp 80 watt.  I replaced the single battery with two 6v.  I like the zamp and it does exactly what i need.   Several other brands are good as well, but zamp will be the most expensive for sure.  I would suggest getting the right size of panel more than a particular brand.  Are going to boondock for extended periods?  what do you plan to use the panel to do for you?
TexMan 2015 182g
2018 Sequoia
TexManMods
henryv View Drop Down
Direct Link To This Post Posted: 30 May 2017 at 2:44pm
What is the best solar panel to use if you are planning to use the one battery that came with the camper. Is Zamp recommended?
