  New Posts New Posts RSS Feed: Bent Axle
Bent Axle
JohnnyMac View Drop Down
Post Options Post Options   Quote JohnnyMac Quote  Post ReplyReply Direct Link To This Post Topic: Bent Axle
    Posted: 21 Apr 2023 at 6:59pm
Just wondering,....I hear a lot about the weak axles in the R-Pod and that they may become slightly bent causing a slight (top-in) cambering of the wheels. My question is,....is there anything unsafe about using it with a slightly bent axle? If it still tows fine, what is the down side??
JonnyMac
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2023 at 8:12pm
The down side is faster wear on the inside edges of the tires. Keep track of the wear as it can wear through faster than you might think.
mjlrpod View Drop Down
Post Options Post Options   Quote mjlrpod Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2023 at 9:52am
Unfortunately F/R continues to make Rpods with axle connection points about a foot or so away from the end of the axle. If you hit a bump or pothole, it leaves the unsupported last foot or so to absorb the full shock of it. Funny thing is, they also build surveyor campers too. Those have the connection point at the absolute end of the axle. Why the heck do they do things like that.
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
GlueGuy View Drop Down
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2023 at 10:17am
I've wondered about that as well. The issue is that the frame is roughly 2' more narrow than the outside of the trailer. Why would they do that? I suspect it is to reduce the weight of the trailer. Adding 2' to the width would mean they would have to do additional bracing in between the outer rails, and that would probably add (at least) a couple hundred pounds to the weight of the trailer.
The downside is that the axle gets cantilevered as you noted. The other issue is that the weight of the walls is bearing down on the floor (hence why we add the outriggers).
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2023 at 5:07pm
We have had a slight bent axle on our 177 for 11 years on the slide side.  Yes, there is some additional wear on the inside tread but after 5 years (when they are replaced) there is still plenty of tread left, even on the inside of the tire.  Traveling over 43,000 miles with this condition, I don't worry about it.
DD08 View Drop Down
Post Options Post Options   Quote DD08 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2023 at 11:19am
We just got our R Pod a few weeks ago, took it into service to get the bearings re-packed and they came back advising we have a bent axle as well. No risks in driving it your just going to wear your tires every 1-2 years, for the cost of tires these days it was a cost we couldn't absorb.
We got one 1 day camping trip with it before we're already looking into selling it or seeing what our options are to replace the axle. Our first quote along to fix a few other things was about $3800.00 and sent us in a tailspin.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2023 at 5:00pm
As stated above we have had this issue for 11 years.  We replace our tires at 5 year intervals with one set having 24,000+ miles on them after 5 years (Hartland tire load range "C").  It was observable that there was slightly more wear on the inside of the tire but there was plenty of tread left, there were no worries as far as safety was concerned even after 5 years and 24,000+ miles.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2023 at 5:40pm
+1. Before going the drastic route, check and see just how bad it is. Unless you are doing multi-thousand mile trips, you may not wear the tires out before they age out and need replacing.
renhui View Drop Down
Post Options Post Options   Quote renhui Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2023 at 9:48pm
I noticed some bent as well (top-in), will keep a close eye on it.
I've seen some videos on Youtube on fixing the axle, have any one tried that before at all?
DD08 View Drop Down
Post Options Post Options   Quote DD08 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2023 at 11:43am
Thanks Jato/Stephen,
Appreciate the input, I think when we hear bent axle not having much knowledge on R pods and trailers we thought it was the end of the road and the thing was done.
we got a second opinion on ours and the Axle is bent about 1/4", We're going to review replacing or just leaving it as is but we've had the tires for about 2 years and the wear appears pretty bad. Pictures to follow.
