rPodCamping
Calendar Event: Attaching Items to Walls ??? Posted: 29 Mar 2020 at 5:15pm |
My wife and I are new rPod owners............in fact, ours is still sitting in Ohio awaiting to be picked up. Like many of you we plan to make some modifications like attaching light-weight racks, clocks, etc. to the internal walls in several places. I realize that it depends upon the weight of the item.......but we would appreciate any recommendations on the best (and worst?) methods to attach items securely to the wall. Also, for heavier items (~10 lbs) is it possible to drill into the wall to use something like a toggle anchor bolt? Thanks in advance for your time.
Posted: 29 Mar 2020 at 5:55pm |
I'd suggest that you take a look at an rPod construction video before attaching stuff to your interior walls. It will help you to better visualize what you have in there. You have a pretty thin luan layer with foam insulation behind that. It would be hard to get an expansion anchor to expand into the closed cell foam. If you are attaching to the side walls and can find the 1 inch square aluminum tubes then you can probably attach something that weighs 10 lbs or more, but if you're just into the luan or in the curved roof areas which don't have aluminum tubing then not so much.
rPodCamping
Posted: 29 Mar 2020 at 7:02pm |
Thanks very much, I do appreciate it.
geewizard
Posted: 29 Mar 2020 at 7:45pm |
We use Command hooks and fasteners. There's a variety of styles and strengths. Home improvement stores have them as does Amazon. They work well.
2004 Outfitter Apex 8 camper
2014 Toyota Tundra DC
rPodCamping
Posted: 29 Mar 2020 at 9:02pm |
Great.............we will check them out. Many thanks....................
JR
Posted: 30 Mar 2020 at 9:40am |
+1 geewizard we use velcro command strips and we have even used it on a large cribbage board, after I take it off the wall and my wife beats me in a game of cribbage I can then hang it back up on the wall as a piece of folk art the command strips work well
Jay
179/2019
rPodCamping
Posted: 30 Mar 2020 at 11:13am |
I can definitely relate to getting beat by my wife at cribbage.............too frequently.
Sounds like this Command brand is highly recommended, and it looks like they are available from Walmart, Lowe's, Home Depot, and other big box stores.
Thank you for the feedback. Stay safe............. I hope we get to go camping this year.
Posted: 30 Mar 2020 at 11:23am |
I've had Command stuff fall off walls before. Seems like it adheres well initially but once its there for few months it often seems to fail. I suspect humidity causes it but don't know for sure. One good thing is that the hangers came off clean and didn't mar the wall finish. Can't say the same for the stuff that fell down though.
Also note that something that weighs 10 lbs will effectively weigh 20-25 in a trailer going down a bumpy road, so plan accordingly.
rPodCamping
Posted: 30 Mar 2020 at 12:23pm |
Ok, thanks.
Forgot about the ride down the road potentially making items heavier and knocking them off the wall. Maybe we take everything done before we go down the rood......
Have you ever tried to use a standard stud finder to locate wood or metal 'studs' (or whatever the correct term used for trailers is...........)? Guess I'll give it a go when we finally get the trailer to our home.
Appreciate your thoughts..............
Posted: 30 Mar 2020 at 1:21pm |
Good question. I haven't tried a stud finder. The side walls have aluminum square tubing so I'm not sure a magnetometer based detector will find that. The old school stud finders with the magnets in them wouldn't. The new imaging ones ought to work.
You might not need that though, you can know pretty close where to look if you review the construction videos, mostly the aluminum frames the doors and windows. Use a tiny drill bit to make a pilot hole, worst thing that happens is you seal up the little hole with a bit caulk. Don't drill all the way through the wall though, its only an inch.
