Page 12> |
Riverrune ![]() Newbie ![]() ![]() Joined: 02 Dec 2019 Location: Colorado Online Status: Offline Posts: 3 |
![]() Posted: 01 Jan 2020 at 2:44pm |
My wife and I are recent R-Pod owners and can't wait for weather thats a bit warmer here in western Colorado.
Ken Neubecker
Welcome and congratulations! I hope you have many fun adventures and make many great memories with your RPod. What model? We have a 2016 179 to which I have made a number of modifications. One of the great things about the RPod is that there are many things you can do to make it uniquely yours. Colorado is one state we have not yet visited. Hopefully, we will remedy that this year.
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3340 |
Congratulations! If and when any problems arise this is your 'go to' destination as well as the facebook side if you are on that social media. What part of Colorado are you from? My niece has lived in Cotopaxi close to 10 years, a nephew in Colorado Springs and our favorite national park is RMNP which is our destination every other year - Moraine Campground is the place to camp. Last September we were on a 30 day excursion to CO and UT, many great memories made and are sure you will have similar experiences with your r-pod.
Woodmiester ![]() Senior Member ![]() ![]() Joined: 03 Aug 2018 Location: Greenwood IN Online Status: Offline Posts: 142 |
We have a 190. We love it and have already done many modifications to it.
I doubled the size of the over sink cabinet, replaced that crazy table, re-worked the under sink storage, converted the closet to a multi shelf pantry and installed a shelf over the bed for linen baskets which holds our clothes. We also installed a foldable clothes hanger in case we need it. (Havent yet). Installed an 8'X6" shelf at the top of the push out for our smaller items in the kitchen and installed a towel shelf above the toilet. I installed a double battery box on the tongue along with duel propane tanks. This trailer is probably the most versatile, adaptable trailer we have ever owned.
Swampfox
LongRanger ![]() Newbie ![]() ![]() Joined: 13 Jun 2019 Location: California Online Status: Offline Posts: 39 |
Where did you buy the materials for dual propane tanks?
Just a word of warning to anyone considering installing dual batteries and/or propane tanks. This will greatly increase your tongue weight which will already almost certainly be significantly higher than the unrealistic number FR provides, so get an actual tongue weight first and be sure your tow vehicle can handle the increased load.
Not sure. I ordered them on the internet. Will take a look and let you know.
As far as the tongue weight goes, the only thing to consider here, I believe, is the tow vehicle capabilities. The A frame of the trailer is the same as many heavier trailers.
Swampfox
I can’t answer for other trailers but I did the structural loading calculation for my 179 with dual batteries, single propane, wdh tensioned, and a full fresh water tank, all of which add downforce on the a frame and longitudinal rails in the area just aft of the a frame. The loads were quite close to the yield limit of the 2x4 box tubing, only about a 2x safety factor to handle the inevitable bump loads. I consider that to be marginal, and since others have reported bent frames I’d be cautious adding a lot of additional load in that area, especially if you run a wdh, or have a forward mounted water tank that you keep full. It’s a robust looking tube but it’s only 1/10 inch thick so it’s not as strong as it might first appear. |
Not sure I would try traveling with 280 lbs of water along with duel batteries and dual gas bottles!
Swampfox
I'm generally boondocking for a week or more at a time so the 250lbs in the fresh water tank, and the dual batteries are a must have. Dual propane tanks are not, one lasts a long time, so I only carry one. If it does run low, I take it with me and swap it out when I go sightseeing or go into town in for supplies or to use a laundromat. I don't put anything heavy in the 179's forward storage compartment either. Everybody has a different use case, so its good to actually weigh your rig and each axle to be sure you're not overloading things.
Page 12> |
