Happy Tripping
Topic: tow vehicle tires and trailer sway Posted: 18 Oct 2018 at 11:59am |
One of the less discussed factors causing trailer sway appears to be the tow vehicle's tires.
From the internet, until about 4000 miles have been run off, new tow vehicle tires by themselves can cause significant sway because of the tread's surface.
?How about the width of the tires?
My Jeep Cherokee Trailhawk has P244 tires, about an inch wider than the usual Jeep tire. I assume that this would have a beneficial effect in preventing/controlling sway because of the bigger 'footprint', just as dual axles help. I don't see, using the 'search' feature, that this has been covered in the forum before.
Posted: 18 Oct 2018 at 4:15pm |
Never heard of that one. I have had new tires on my 94 F-150 and never experienced sway pulling our 177. On the other hand we could never travel above 35 mph with our 08 Explorer and NOT have sway. A sway bar was mandatory on that vehicle. With our 13 Explorer we have traveled at speeds of 55 mph w/o sway bar and again, no sway noticed. I did that for a test even in cross winds, otherwise I use the sway bar link. The only reason i can figure on the difference of the 2 Explorers was the width between the tires. The newer one was wider, hence better tracking. As far as pulling with our '95 F 150 with manual transmission my only concern is hitting more deer. With 320,000 miles it has 31 deer kills, good thing it sits tall and has a real bumper on the front. Have already hit 3 so far this year, but no kills as far as I know; even though they were pretty well banged up. Would not want to hit one with the Explorer, with one hit I think it would destroy the vehicle. Tires on all 3 vehicles above were the standard size that came on them when purchased.
Posted: 18 Oct 2018 at 4:26pm |
I read on the internet that deer kills increase the likelihood of trailer sway, and of course, everything you read on the internet is true, right? Jato, can you confirm?
Posted: 18 Oct 2018 at 5:25pm |
First I have heard this one too. I can say my D rates handle better than my 14" C rates. As far as sway not noticeable. I eliminated my sway issues very early in my Pod towing experience.
Posted: 18 Oct 2018 at 5:42pm |
I think Happy Tripping is talking about sway occurring after changing to new tow vehicle tires. Nothing to do with trailer towing but I've put new tires on cars before and had them feel squirmy for awhile before the tires break in a bit.
Could be that the squirminess results in some sway, could be sidewall stiffness variation, could be tire pressure a being bit low. FWIW, I just put new tires on my TV and noticed no squirminess on the TV or sway tendency on the trailer.
If that's what they're talking about and your rig is that sensitive that a little tire squirminess causes sway you should probably think about redistributing some weight and adding/increasing sway control.
Keith-N-Dar
Posted: 18 Oct 2018 at 5:52pm |
When radial tires were new o the American market I worked in a gas station and we were told to tell customers that the first 100 miles the tires were breaking in and traction issues could occur. They also could not be rotated so they moved in the other direction than they had originally be mounted. My tire dealer tells me this is no longer the case on either. My bet this internet wisdom is old. I cant imagine the liability a tire manufacturer would have if they sold tires that caused sway.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Posted: 18 Oct 2018 at 6:03pm |
I'm with Keith. I'm not sure I'm buying a tire break-in. In fact I know I'm not. BTW - what is sway on a tow vehicle without a tow?
Posted: 18 Oct 2018 at 8:05pm |
[QUOTE=offgrid]I read on the internet that deer kills increase the likelihood of trailer sway, and of course, everything you read on the internet is true, right? Jato, can you confirm?
I have to oppose that 100%. Deer kills do not increase the likelihood of trailer sway. That being said, when a deer jumps in front of the TV and you swerve to hopefully avoid a collision, trailer sway then becomes a real possibility.  The deer in northern Michigan think they are pretty smart,"Hey Joe, watch that truck lock up the brakes as I jump out in front of him, or watch the whites of his eyes as I gracefully jump over his hood." Meanwhile the F-150 replies, "If it's brown, it's down."
Posted: 19 Oct 2018 at 4:41am |
mcarter, there is no trailer sway without the trailer. It was just my bad sentence structure. nothing to do with trailer towing means that when I noticed initial squirminess when I put on new tires it was just while driving the car. And that was a long time ago and on a sports sedan.
To be clear, I don't buy the sway increase argument either, I'm just speculating where this particular urban legend might have originated. Like I said, I just put new tires on my TV, no squirminess, no sway tendency, better stability and ride from day one.
DavMar
Posted: 19 Oct 2018 at 10:30am |
Jato, by chance do you have a crash bar on the front of your F150 and enjoy road kill tenderloin?
wonder dog.
2017 Rpod 180
2016 Toyota Tacoma SR5 4x4
Lexington, NC
