Page 12> |
J and B ![]() Newbie ![]() Joined: 20 Sep 2017 Location: FLA. Online Status: Offline Posts: 9 |
![]() Posted: 19 Dec 2017 at 6:34am |
Hi. Florida person here. Camping in the panhandle for the Holidays, temps are predicted to drop to 29 degrees
Tars Tarkas ![]() Senior Member ![]() ![]() Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1454 |
Hmmm. I'm camping in the Panhandle and the temps are in the 60s and 70s. But to answer your question, no, 29° is nothing to worry about -- unless it doesn't get above 32 for a few days. You will be fine with overnight temps down to the low 20s as long as it warms up in the daytime.
TT |
FJ Cruiser |
You will be fine. The park may ask you to disconnect your water hose overnight. No problem.
Leo B ![]() podders Helping podders - pHp ![]() Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4518 |
Agreed, 29 at night should be nothing to worry about. That is still t-shirt weather here
Heading that was Christmas to New Year. Prediction is 29 degree. Thanks!
Larry-D ![]() Senior Member ![]() Joined: 12 Oct 2017 Location: Middle TN Online Status: Offline Posts: 113 |
For what it's worth. We were camping a couple of weekends ago in our larger TT with an enclosed underbelly, heated by furnace ducting. Temps got down to 19 and 20 degrees. The only thing that froze was the black tank's dump valve. Left without dumping the black tank and the grey tank since we use the grey water to clean the sewer hose.
I agree with maybe unhooking the water hose, just in case. You might also think of putting some RV antifreeze in the grey and black tank before you get anything else in there. My thinking on this is that if it is mostly antifreeze at the dump valves at least the valves won't freeze; however the antifreeze will dilute some as stuff goes in the tanks. Wouldn't take much, just enough to get down to the valve and up the drain pipes a little toward the tanks.
Leo,
Do they make fleece lined T-Shirts? Anything below 60 is deep winter to me:) |
Camco makes heated potable water hoses.
https://www.amazon.com/Camco-22911-Heated-Drinking-Thermostat/dp/B01ABONB0A/ |
We have a heated hose. They work great; however the water faucet can freeze so I throw a canvas tarp over it and make it into a tent so any heat in the ground is captured in the "tent" and keeps the water supply faucet from freezing. Also the fitting on the trailer can freeze even with a heated hose. We wrap a towel around the fitting and hold it with a bungee cord. No problems down to 19 degrees.
I've seen others use PVC pipe insulation like in a house or even swimming pool noodles. Anything that insulates the hose will help.
Page 12> |
