Page 12> |
Author | ||
Johncmarshjr ![]() Newbie ![]() ![]() Joined: 24 May 2017 Location: Maine Online Status: Offline Posts: 21 |
![]() Posted: 01 Jul 2017 at 6:09pm |
I just replaced the anode after one year. It was almost gone. I would suggest they be replaced annually. $12 can save a lot of headaches.
ALICE
It depends on the water, after 6 years, ours was still about 50%.
I inspect mine every year during winterization. When it gets to 50% I replace it. Water and use are the two primary reasons for deterioration.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6435 |
Some areas have water that is very corrosive. The anode rod would not last long there. I changed ours when we picked it up from the factory. It was about 50%. Another thing that will cause it to corrode quickly is if you did not have the water heater bypassed and RV antifreeze got in there.
ToolmanJohn ![]() Senior Member ![]() Joined: 23 Apr 2014 Location: Connecticut Online Status: Offline Posts: 451 |
After 4 years, mine was almost ready to replace. That was almost 100% strictly with my city water too. Only a few times did I fill at a campground, and regardless of water source, I used a Camco inline filter element on the hose.
The anode rod looked like Swiss cheese, but had about 40-50% left by my estimate, and the inside of the tank looked good. Shine a flashlight in there after removing the anode rod/drain to take a look.
POD WE R ![]() Groupie ![]() Joined: 16 Feb 2017 Location: Arizona Online Status: Offline Posts: 42 |
I check mine every 6 months and clean it with a wire brush. I replace it yearly regardless of condition. E&M 2017 180 HRE Arizona
Tars Tarkas ![]() Senior Member ![]() ![]() Joined: 14 Jan 2013 Location: Near Nashville Online Status: Online Posts: 1454 |
To each his own but that's kind of like changing a lightbulb every year whether it needs it or not. TT |
FJ Cruiser |
True, but I do agree with other's that it's cheap insurance regardless of need. Probably every other year would be better. We all have to winterize (well, most of us anyway) and when the hot water tank is drained, the anode rod gets inspected. It wouldn't hurt to put a spare in the outdoor storage, just in case.
MoPod ![]() Senior Member ![]() ![]() Joined: 10 Oct 2013 Location: Pittsville, MO Online Status: Offline Posts: 106 |
Can someone explain the danger of not replacing an anode immediately when it becomes "used up"? I was under the impression that the anode protects the tank from attack by hard water or chemicals in the water. Clearly you wouldn't want to go forever without replacing the anode, but if sometime during the season if it became "used up" and didn't get replaced until the fall when your winterized what danger would there be?
It seems like folks are carrying a lot of stuff and replacing a lot of stuff just in case.
Bill & Nancy
2015 RPod 179 Previously 2010 RPod 176 2014 Explorer Sport |
The anode rod gets attacked instead of the tank. It helps to prevent galvanic corrosion due to water quality. I do not know how fast the corrosion would happen if the anode rod wasn't present (worn completely).
Every hot water tank has an anode rod, even your home water heater tanks have a sacrificial anode rod which must be inspected regularly or you risk corrosion of the tank.
Page 12> |
