  New Posts New Posts RSS Feed: Bent/Broken Axle ETC.
Topic ClosedBent/Broken Axle ETC.
Direct Link To This Post Topic: Bent/Broken Axle ETC.
    Posted: 23 Sep 2017 at 12:25pm
Originally posted by marwayne
Now if that isn't true, why does my pod weigh a 150# more with WDH then without.
It sounds like your WDH is too big, or is adjusted incorrectly or some combination of the two.
I recommend everyone go to this web site: https://www.ajdesigner.com/apptrailertow/weightdistributionhitch.php and punch in your numbers. At the bottom it will display a bunch of gauges showing red or green for all the various different parameters.
Jasp View Drop Down
Direct Link To This Post Posted: 23 Sep 2017 at 5:01am
Sorry Dave. I too crawled under for a look. It's definitely good information and something I've never heard of before. Makes sense though.
Paul
DavMar View Drop Down
Direct Link To This Post Posted: 22 Sep 2017 at 10:28pm
+1 Jasp, Good information! Now your going to make me crawl under my trailer to check out what the axle is rated. Confused
wonder dog.
2017 Rpod 180
2016 Toyota Tacoma SR5 4x4
Lexington, NC
Jasp View Drop Down
Direct Link To This Post Posted: 22 Sep 2017 at 4:52am
Interesting axle WDH video
https://m.youtube.com/watch?v=lVg8QgIFJoU
Direct Link To This Post Posted: 21 Sep 2017 at 11:12pm
I found out2 years ago that my Dexter axle was only 3000#, replaced it with 3500# after 2 years camber is gone. I will replace with 4500# or 5000#
bobt49 View Drop Down
Direct Link To This Post Posted: 21 Sep 2017 at 10:02pm
Well, I don't want to be scolded so lets put an end to this conversation.  However, I do believe that it is a good idea to take note (pictures) of your Pod's wheels and their relationship to the wheel wells.  If things start to get out of kilter, have it checked out.  could save you some grief down the line.
By the way, I have no intention of getting rid of our Pod.  With the upgraded axle I think it will be very reliable while meeting our camping needs.
Bob & Cindy
San Francisco Wine Country
RPod 177
Nissan Titan
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 21 Sep 2017 at 8:27pm
Originally posted by bobt49
Regarding the general comments above.  I understand the Rpod is relatively inexpensive.  Also, I do not mind fixing things and modifying the unit to fit my needs and interests.   However, I must conclude that FR put the "Hood River Edition" on lifts with macho tires only as a  marketing  ploy.  That I do not appreciate.   I would have happily paid more for a more heavy duty trailer.  The $1,000+ new axle and  modifications I am putting on now would have been relatively inexpensive if they were included in the original build.
Be careful.  I was scolded for making a similar comment about Hood River pods.
Fact is by far most pods never have axle problems.  Is it to light? I don't know.
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 21 Sep 2017 at 6:37pm
Direct Link To This Post Posted: 21 Sep 2017 at 6:19pm
Originally posted by Jasp
Bob,
Are you using a weight distribution hitch ? I have learned that a weight distribution hitch on a loaded truck bed will actually transfer the bed weight to the trailer axle thus causing overload of certain single axle trailers
That is not true. A WDH will not transfer any of the truck weight to the trailer. All a WDH hitch does is transfer "some" of the rear wheel load on the TV to the front wheels. How much is determined by the settings on the WDH.
IOW, a 3500 lb trailer with a tongue weight of 350 lbs without a WDH puts pretty much all of that 350 lb to the rear wheels of the TV. WITH a WDH, a portion of that gets shifted to the front wheels of the TV. In a typical situation, you'll end up with ~~ 200 lb on the rear wheels, and ~~ 150 lb on the front wheels.
These are not hard and fast numbers, they are speculative on what would be "typical".
In any case, the weight on the axle of the trailer does not change.
Direct Link To This Post Posted: 21 Sep 2017 at 6:16pm
Bob & Cindy
RPod 177
Nissan Titan
