  New Posts New Posts RSS Feed: Bent/Broken Axle ETC.
Topic ClosedBent/Broken Axle ETC.
bobt49 View Drop Down
Direct Link To This Post Topic: Bent/Broken Axle ETC.
    Posted: 21 Sep 2017 at 6:04pm
No weight distribution hitch.  The frame and axle specialist working on it said the original axle was only a 3,000 capacity axle and may have been defective from the git go.  He is replacing it with a 3,500 # Dexter axle that he believes will be better suited to the Rpod.  He is also reinforcing the lifts and frame.
Bob & Cindy
San Francisco Wine Country
RPod 177
Nissan Titan
Winterpod View Drop Down
Direct Link To This Post Posted: 21 Sep 2017 at 5:49pm
when I brought my WDH for my 178,
I got the E-2 400-4500 model. It was more expensive than
the 600-6000 model, but I didn't think I needed a 600 lb.
tough weight hitch for a 350 lb. tough. So far its performed
well. The argument that if I ever moved up to a larger unit I
would be set did not make any sense to me. If I move up to a larger
unit it will be the biggest baddest toy hauler any one has ever seen.Star
Happy Tripping View Drop Down
Direct Link To This Post Posted: 21 Sep 2017 at 5:22pm
Originally posted by sean p
Last month had the axel fixed ... After 2 years i now see the quality issues. Little things keep breaking and i'll keep fixing.
Just for general information -
1. I do feel the axles are too light, but as far as I can see, it's 'industry standard' for ultralights like the R-Pod. At least as far as I can see, all the competitors also have the same light axles.
2. I believe the R-Pod, at least for our 171, stands right at the point on the graph where the lines cross measuring the best-quality at the lowest-price.
3. Fixin' things is part of having a travel trailer, or a house.
Direct Link To This Post Posted: 21 Sep 2017 at 4:43pm
Jasp,
Unfortunately many RV folks will not read your post. I think it was very interesting. Take a over capacity TV, add a WDH and expect no change. The end result is that weight transfers somewhere, and you could be possibly spot on it moves back to the trailer axle. It's not rocket science.
Jasp View Drop Down
Direct Link To This Post Posted: 21 Sep 2017 at 10:53am
Bob,
Are you using a weight distribution hitch ? I have learned that a weight distribution hitch on a loaded truck bed will actually transfer the bed weight to the trailer axle thus causing overload of certain single axle trailers
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 18 Sep 2017 at 7:45am
I know exactly how you feel. Last month had the axel fixed and 2 new tires. 500$+. After 2 years i now see the quality issues. Little things keep breaking and i'll keep fixing. Looks like 1 more year with the pod then looking at class b's.
My friends with motor homes fix things too.
2011 R-Pod 177
2010 Ford F-150
sean p View Drop Down
Direct Link To This Post Posted: 18 Sep 2017 at 6:54am
2016 179pod--BETTY
2010 nissan frontier
Sean and Doug
Butchie the morkie
touring the west
Direct Link To This Post Posted: 12 Sep 2017 at 5:33pm
My 2011, 177 Pod has a bent axle.  This is just one more example of a good overall concept, RPod, that was poorly assembled or, in the case of the axle, with a critical system that is right at the ragged edge of it's design capacity.  I noticed the problem when checking tires.  The driver's side wheel was so far out of alignment (picture below) that a groove had been gouged in the tire tread by a screw used to hold on a running light.  My local running gear expert mechanic checked it out and the axle is bent, camber and toe in is way out and the lift kit has a crack.  This wouldn't be so disturbing if I had routinely taken the pod off road like it's huge mud and snow tires and lift kit imply it is capable of.  However, I have owned this pod from day one and babied it always.  It has less than 10k miles on it.  It has never been off road and I carry everything in the pickup bed except food, clothes and 3 gallons of water when traveling.  Always empty grey/black water tanks and drive at 55 MPH, which is the limit in California.
Another poor construction example: Air Spoiler that is screwed into the "One Piece Fiberglass Roof" with plane steel screws unprotected by even a dab of self leveling caulk.  So they rust out, leak and allow the spoiler to warp.  The warped spoiler then allows rainwater to enter the 3" diameter running light wiring access hole in the "1 Piece Roof" and cause havoc.
Another example: Who really believes that a couple of No 8 self tapping screws will hold light fixtures, Venetian blinds etc when they are screwed into wall board that is about 1/8" thick? I must have put in 40 screw anchors so far.
OK, Rant over.  Everyone, be warned: check your wheels/axle.  If this had happened a long way from home, we would have been out of luck.  It takes many weeks to get an axle shipped from the manufacturer, assuming you can find someone to do the work.  You may not be able to limp home.  I have done a lot of research since I discovered the problem and torsion axles continue to fail until the tire contacts the wheel well and then all hell breaks loose.
Bob & Cindy
RPod 177
Nissan Titan
