  New Posts New Posts RSS Feed: slide out for rpod 179  2017
Topic Closedslide out for rpod 179 2017 - Event Date: 06 Aug 2017
OZL View Drop Down
Direct Link To This Post Calendar Event: slide out for rpod 179 2017
    Posted: 06 Aug 2017 at 6:46pm
What If you, for some reason can't open your slide out, with it's motor.
Direct Link To This Post Posted: 06 Aug 2017 at 7:14pm
Is this an actual problem or something about which you are concerned may happen? Check out YouTube videos for what to do in the case it happens. We have had ours for 1-1/2 years and have moved the slide-out out and in many times. It has given us no problems, even with it going through some harsh weather and being in an accident (which got it a trip to the factory for repair). The slide-out seems to be very reliable, so relax and enjoy it. Just be sure to move it out and in all the way and don't stop in the middle if you can avoid it. That helps the two motors to stay in sync. There are videos for what to do if they should get out of sync, but if you always put if all the way out (hold the button for 3-5 seconds after movement stops), then the motors should stay in sync.
OZL View Drop Down
Direct Link To This Post Posted: 07 Aug 2017 at 8:47am
Thank You...We are new Podders...We will just relax and enjoy it...Meantime I read all your hints about extra storage...Like your innovations...Frew and Curtis
LLee View Drop Down
Direct Link To This Post Posted: 12 Sep 2017 at 5:18pm
Our new 177 R Pod slide out did not want to open. We spent the night in a VERY COZY RPod and then got the control box fixed by a wonderful RV repair place in Prineville Oregon. The YouTube videos are good to tell you what to do when the slide out doesn't want to come in.
LLee
2017 new 177 owner
Toyota Tacoma 4x4
Direct Link To This Post Posted: 12 Sep 2017 at 5:54pm
+1 with Stephen, u
Have used our 2015 179 a lot with no problems. I thought there is a video on YouTube that showed you how to disconnect the motor so you could slide it out if you had too. But the mobile RV repair man is a wonderful thing!! Have used them a few times!
OZL View Drop Down
Direct Link To This Post Posted: 13 Sep 2017 at 4:28pm
Looked at the youtube and got the idea of what to do if "The Slide Out Doesn't">Thank you all! Curtis and Frew
