Weight distribution/anti sway - Event Date: 23 Jul 2017 |
Page <1234> |
![]() ![]() ![]() ![]() Posted: 25 Jul 2017 at 11:21am |
Higher weight rated WDHs are harder on the tow vehicle structure because they don't absorb as much force. This is especially important if you're using something like the Highlander, which is unibody. Ideally, you should get the next size above your actual tongue weight.
@rawest50: The low numbers are the tongue weight values. Typically, WDHs are rated by tongue/pull weight (e.g. 600/6000 for the E2 I use). I suspect your 10000 pound rated WDH is 1000/10000. |
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2706 |
ToolmanJohn ![]() Senior Member ![]() Joined: 23 Apr 2014 Location: Connecticut Online Status: Offline Posts: 451 |
As long as you don't have sway or handling problems, it was the right thing to do. Most people (myself included) have been trained to believe that only a 10-15% tongue weight is safe and less is not safe and unacceptable. This simply is NOT true of ALL trailers and tow vehicle combinations.. ALL travel trailers built in Europe have about 8% tongue weight recommendations. They tow at a LOWER regulated speed limit when a travel trailer is in tow. They are not allowed to exceed those limits. The trailers are also built lighter and have their mass central near the axle(s), no heavy kitchens and baths options near the ends of the trailers. High speeds EQUALS sway. In the US, people expect that they should be able to tow their trailer at the posted speed limits, whether it's 55 or 80 mph. This is a problem for trailer manufacturers who make all these heavy optioned out trailers, the only way to keep it safer at high speeds is either to centralize the mass or increase tongue weights. This means bigger and bigger tow vehicles for heavy trailers. It means weight distribution and sway control HAD to be invented, or trailers would still be small light canned hams. I think it's safe to expect that a tow vehicle can pull 1.5 times it's own weight. 8% or more tongue weight WITH sway control. My new toy hauler will range from 9% (lightly loaded) to almost 11%(fully loaded to gross carrying capacity). It just fits within the maximum capacity of my SUV. My SUV weighs 5000 pounds. Of course testing is key. When you have your rig setup as expected for towing, always give it a test wiggle at highway speed (starting at 50 mph) to see how it behaves. Do it safely when no one else is near you. Watch for the trailer to straighten out nearly immediately when you center the tow vehicle again. I did this many times with my 177 when I first owned it, and I will again with the new trailer in the next couple of weeks. I want to know exactly how it will behave. Then there's crosswinds, semis, road surfaces, these things will all come in time but it's best to be able to know it's already stable when things are right.
rawest50 ![]() Senior Member ![]() ![]() Joined: 07 Mar 2017 Location: Arkansas Online Status: Offline Posts: 440 |
ToolMan you are absolutely correct about weighing tongue weight. Bought a scale. Found out I was loading 400 pound tongue weight but less than the 3,500 I can tote. Rearranged load in the Pod and got it down to 300. Readjusted again and got it up to 330.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler 2017 Chevy Colorado Z71 Off Road Crew Cab 2 Weiner dogs Great wife puts up with my BS ❤️ Thoroughbred Racing. ![]() |
Get the trailer tongue weight measured. Preferably when loaded, full propane, battery(ies), full fresh water, all cargo, all you expect to bring with you on your trips.
Weigh it. Weigh it. Weigh it. You cannot select your WD tension bars until you weight it, otherwise you're guessing. WD bars too strong and it will be very rigid and possibly unsafe, too soft and it won't help with weight distribution. Alternately, the Anderson has NO tension bars, and uses a different torsion method for distributing weight. It worked very well for my R-Pod 177, it controlled the up-down porpoising effect very well, and my Pod was level after adjustment. Only slight sag on my tow vehicle. Never had any indication of sway. It is adjustable for trailers up to (supposedly) 14,000 pounds. I know from experience it doesn't work well at 5000+ pounds. I tried it. And I had to buy a different brand for a new bigger trailer. I purchased a Blue Ox (1000 pound bars) for my new trailer (550-800 pound estimated weight range for tongue), but haven't had the chance to use the trailer on a camping trip yet. Can't wait for the second week of August!! The Blue Ox was $615. The Andersen was $500.
PilotPodder ![]() Senior Member ![]() ![]() Joined: 04 May 2016 Location: Portage, MI Online Status: Offline Posts: 305 |
The one thing to note is that the Equalizer can be pretty noisy. I went from using the Equailizer on my 2016 Rpod 171 for the entire season (2,200 miles) to a Blue Ox now with my new 179 (about 1,300 miles so far). The Blue Ox is much easier to use in my opinion and much less noisy. I have the 500lb bars meaning it will take up to 500lbs tongue weight and 5,000lbs trailer weight. The 179 is just about 300lbs tongue weight and 3,000lbs trailer weight. I have had great safe towing with both WDH's, but would recommend the Blue Ox for easier use (attach/detach) and quieter operation. It is likely more expensive, but I do not know.
I have the e2. Not sure wher the low numbers are coming from unless it is the model. Mine in 10,000 pound rated pulled by 2017 Jeep Unlimited. I think it cost me about $360. Easy to hook up. Not kidding when I say the Jeep's control is amazing as far as handling. Pod tracks beautifully. Biggest problem is HP. But sway and load have nothing to do with that.
2017.5 RPod 179
Johncmarshjr ![]() Newbie ![]() ![]() Joined: 24 May 2017 Location: Maine Online Status: Offline Posts: 21 |
Very helpful and thank you. Is there a detriment to going a bit larger, i.e. The Fastway 800 instead of the 600 for the Rpod 179?
ALICE
Richand Cindy ![]() Senior Member ![]() ![]() Joined: 16 Apr 2016 Location: New Jersey Online Status: Offline Posts: 328 |
You are definitely doing the right thing getting WDH and antisway. You can get either the cheaper Fastway E2 600 lb model which has two point sway control, or the more expensive Equalizer or Blue Ox which have four point. Our dealer who sells all three said for the RPOD the Fastway is plenty so we bought it and it is great going over steep hills and windy highways
NEW: 2018 Passport Elite 23RB + 2017 Ram 1500 Diesel |
For simplicity, you should look at a system that combines WD and anti-sway. I have been using the Equal-i-zer 4-point sway control hitch. It has served me well except for once when ice and wind were too much for it to correct. I doubt other systems in the price range would have done any better in that situation. It works well, especially if one uses a hitch tightener to stop the hitch shank from clunking around in the receiver. Another option is the Fastway E2 hitch which uses 2 point sway control. It is similar to the Equal-i-zer as both are made by Progress Industries. It is less expensive, but probably not quite as good on sway control. A third option is the Andersen No-Sway hitch. Unlike the bars of the above two hitches, the Andersen uses chains and urethane (I think) "springs" to accomplish the weight distribution. The sway control is accomplished by the hitch ball which is locked in a sheath or friction material so that it resists turning. It is the lightest weight of the three systems I have mentioned. There are others also which you can find by searching. Some of them, like the Jim Hensley ProPride hitch cost $2445.00 (plus $195 shipping). Admittedly, it is probably the best hitch available, but it is way too much. |
Page <1234> |
