  New Posts New Posts RSS Feed: R-dome attachment "thingies"?
Topic ClosedR-dome attachment "thingies"?
Direct Link To This Post Topic: R-dome attachment "thingies"?
    Posted: 03 Jul 2017 at 11:39am
We think we want to make our own semi-sort-of awning. Our R-179 was built with the track used for the R-dome, and is not reinforced to use the factory awning. The R-dome itself is "too much", we just want a shaded area on the entry side of the pod (that is quick and easy to put up/take down).
However, I've never looked at an R-dome up close, so I'm not sure how it attaches to the side of the pod. I'm assuming there are some sort of buttons or other thing that is sewn into the edge of the R-dome. That's what we need. Does anyone know where we can get these thing(s)? As an alternative, if anyone has a torn/worn out R-dome, we would like to recover the track slider things.
Direct Link To This Post Posted: 03 Jul 2017 at 1:40pm
Sail slugs, or keder tape. Those are the two most often sourced ways to mount a home made awning.
Live2Camp View Drop Down
Direct Link To This Post Posted: 03 Jul 2017 at 2:01pm
Aha! I found listings for both sail slugs and keder tape (as recommended by furpod) on www.Sailrite.com
 They're my go-to source for such things as I own a Sailrite sewing machine.
His:Ford F150 double cab 4WD; Hers/mine:Tacoma V6 double cab 4WD
Still love rugged, diggin' comfy too
geewizard View Drop Down
Direct Link To This Post Posted: 04 Jul 2017 at 9:37am
I bought a REI Camp Tarp (12x12), two REI tarp poles, and made my own slider attachments with parachute cord and nylon spacers from Home Depot.  The Home Depot part is  1/2" x .194" x 1"
http://www.rei.com/product/893999/rei-co-op-camp-tarp-12
https://www.rei.com/product/845322/rei-co-op-adjustable-tarp-pole-single
http://www.homedepot.com/p/Everbilt-1-2-in-x-1-in-x-0-194-Inner-Diameter-Nylon-Spacer-814988/204276570
Or you could buy them:  http://www.ebay.com/itm/Tarp-Trackers-awning-hangers-Tent-Trailers-Pop-up-RV-motorhome-lights-hooks-/251934547549
What I made works for me.
2004 Outfitter Apex 8 camper
2014 Toyota Tundra DC
Direct Link To This Post Posted: 05 Jul 2017 at 6:48pm
How tight are those spacers? When we looked at our R-pod the other day, the keder rail for the R-dome "looked" like 1/2", but I didn't have a measuring stick, so I stuck my pinky finger in. Seems darn close to 1/2", but it could possibly be 7/16".
Poking around online, and keder standard sizes appear to be 8.5mm, 10mm, 11mm, 13mm, and 15mm (there are other smaller sizes). 11mm is "almost" 7/16 and 13mm is "almost" 1/2".
Does anyone know for sure what size the R-dome rail is?
The rail on the outside of the gutter above the slide-out appears to be 5/16" (AKA 8.5mm).
Direct Link To This Post Posted: 05 Jul 2017 at 6:57pm
Older Pods have an inside of .40" (9-10mm). Newer models have the larger, .563" (14mm) inside diameter rail. A quick way to tell is if your rail appears to have an inside diameter larger than 1/2", you have the newer, larger rail.
Pod People View Drop Down
Direct Link To This Post Posted: 06 Jul 2017 at 7:39am
We have an older(2009) model R Pod.  We just finished making a tarp and used sail slugs that were 7/16"-they worked fine.  I think they were labelled as 7.5mm also.  They came from Sail Rite company
here is the item we used
http://www.sailrite.com/Slug-Bail-SS-With-Rocker-7-16
hope this helps
Vann
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 06 Jul 2017 at 8:31am
The reason I used 1/2" nylon spacers for my RPod tarp is that they fit the newer rail.
Direct Link To This Post Posted: 06 Jul 2017 at 8:53am
OK. Our's is a 2017, so it must be the 1/2" (+) rail.
Shopping around it looks like 1/2" keder is only available in bulk. Right now looking at 110 yard roll. Shocked
Direct Link To This Post Posted: 06 Jul 2017 at 2:41pm
another option is to sew a length of rope or coed into a pocket sewn into the edge of the tarp/fly/fabric.
