Page <123> |
![]() Posted: 28 May 2017 at 8:17pm |
Maybe you need to pressurize the holding tank..
Tars Tarkas ![]() Senior Member ![]() ![]() Joined: 14 Jan 2013 Location: Near Nashville Online Status: Online Posts: 1454 |
Sounds like you've narrowed it down. Glad it's not the pump. Maybe a crack or a loose fitting.
TT |
FJ Cruiser |
Not sure how to pressurize the holding tank, with the vent by the filling hole, might be a bit of a challenge. BUT anyway it was decided to fill the tank to full by adding the other 20 gallons. Hooked up the water pump and ran it for probably another 20 seconds while it continued to sputter air and spurt water. Then all of a sudden a steady stream of water came out of the cold side which I was running at the kitchen sink, switched it over to the hot side to purge out all the air, then to the shower sink and finally to the water closet. Now I am really confused
Hmmmm. Interesting. Probably some sort of air lock, which I'd think a self-priming pump should be able to deal with. Yeah, might have been worth a busted watch if you found the problem and understood how you fixed through your efforts and ingenuity. Really frustrating when you go through all that and don't come out any better or wiser than when you started. It does work now though!
TT |
FJ Cruiser |
Jato, Good. All sounds familiar to me, still have no idea why.
I so wanted you to ask how... LOL Had a whole procedure with 72 steps and needing 5 hands to do it worked out.. ![]() |
GlueGuy ![]() Senior Member ![]() ![]() Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2709 |
I concur with TT; I think you had some air in the line, and you just hadn't purged it all yet. Glad you got it "fixed"...
I think that having more water in the tank (e.g. full) makes it easier for the pump to pick up prime since it does not have to lift the water as much. I'll get a chance to verify this when we pick up our 'Pod next month.
SH,
I never had this issue until I winterized with air. I had the same issue as Jato, the self priming pump is not a "rapid" self priming pump. The only thing I did to assist was siphon some water thru the antifreeze add line with the pump, that seemed to speed it up. I never had a full FW tank. It just took time for pump to get water. Debatable, but air winterization leaves no water in lines and antifreeze winterization has liquid. Last year when I did antifreeze never had issue. Agree best to try on your own when you get Pod back. Interesting. |
Interesting in that except for the first year I owned this pod I have always used air to winterize my 177. Since 2012 that has been the standard and this is the first time this ever happened. So while I am glad everything works well I am discouraged in that during this process I didn't gain the understanding of what exactly I did or didn't do that caused the problem and/or the cure. Life and experiences go on. . .
Page <123> |
