  New Posts New Posts RSS Feed: SLO-Pod 180 mods, John&Sue
Topic ClosedSLO-Pod 180 mods, John&Sue
 Post Reply Post Reply Page  <1 45678 10>
CountryBoyCityGirl View Drop Down
Direct Link To This Post Topic: SLO-Pod 180 mods, John&Sue
    Posted: 29 May 2017 at 11:42am
Love your mods! We have the same model and have some questions: What brand box did you get to house your dual battery system? Where did you purchase it? Was it easy to switch to dual propane tanks?
2008 Land Rover LR2 HSE
1999 Ford Expedition 4x4
2018 R-Pod 180 "Bandit"
CLynn View Drop Down
Direct Link To This Post Posted: 13 May 2017 at 12:35pm
Thanks for the info! Appreciate the help!
voisj View Drop Down
Direct Link To This Post Posted: 13 May 2017 at 9:56am
Clynn,
 Congrats on the new 180!
 On the 180 the undermount carrier goes in front of the pods tires with no effect on the ground clearance.
 The model # I installed was 28215
Check chetc's post for a good how to.
I read it and then bought one and installed it using his instructions.  Only change was the hood River had
 wider tires so I had to lower both brackets. There's a picture in on page 1 of this tread.
rgds John
SLOPODMODS
John&Sue,SLO,CA
Direct Link To This Post Posted: 12 May 2017 at 5:53pm
 Thanks for the detailed postings! Nice job on all the work!
I've been looking at the undercarriage spare tire carriers online and came up with the same one you did. (BAL Model# 28218?) Do you have enough ground clearance after installing? Just picked up RP 180 a few weeks ago-1st TT, so very green at this point! The forum has been super helpful.
Direct Link To This Post Posted: 01 May 2017 at 11:48am
Jacob, love to post the twin bed how to for you and will do it as soon as I get back to the west coast. I'm wandering the Appalachians,and should be home in a week or two,and if you didn't find the " twin bed mod" search for it,there is more info there.
rgds john
SLOPODMODS
John&Sue,SLO,CA
Jacob Orbach View Drop Down
Direct Link To This Post Posted: 30 Apr 2017 at 6:34pm
Dear John,  We love your twin bed modification.  I consider myself semi handy.  Would you consider sharing your modification and provide as much detail as possible.  I am 6'1" tall and current sleeping arrangement is not working for me.
Direct Link To This Post Posted: 29 Mar 2017 at 12:30pm
Texman, nice, looking forward to seeing it! On the wood try to make sure you get a kiln-dried piece with low moisture content that way it won't want to twist and bend so much. Good luck! I do have a bunch more pictures if you want them let me know. Regards John
SLOPODMODS
John&Sue,SLO,CA
texman View Drop Down
Direct Link To This Post Posted: 29 Mar 2017 at 9:59am
yes, i am trying to do the outdoor table.  I ordered the tool from amazon already.  it will be useful for many things i decided: boats, trailers, pods, etc.  I have used the studfinder some in the area between the window and the door.  It picks up something, but not what i think is an aluminum stud.  I think i have to do exactly what you said: three points using the stud by the door or a shorter table.  i may have to have the mounting board a bit longer than the table on the side next to the door so the table will fold up and clear the mounting hardware of the handle. My plan, at this point, is to rip a 2x6 redwood to 3/4" for my table and assemble as you did.  Should be light, plenty strong and look good with a nice stain and finish.
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 28 Mar 2017 at 10:33pm
Texman,
 Not sure if your going for the outdoor table, but instead of Instead of buying the thread insert tool you could just get these, I get them at ace hardware and they are about .50 cents each. I think they call them Jack nuts. They come with a little tool that holds the insert while you tighten the bolt which draws the threads closer and smashes them up against the back of the aluminum, The tool is $1.
  It does look like you would get three mounting points, one by the door, then either side of the window. Not sure but I think the grab handle would still fold flat. Or just shorten the table up to a little bigger than under the window and get 2 good mounting points.
rgds John
SLOPODMODS
John&Sue,SLO,CA
Direct Link To This Post Posted: 28 Mar 2017 at 11:43am
i will get the stud finder out.  has to be something there, might be wood? That area is the bathroom on the 182g.  maybe they use different material there.
TexMan 2015 182g
2018 Sequoia
TexManMods
