  New Posts New Posts RSS Feed: Murphy Bed
Topic ClosedMurphy Bed
Clejo View Drop Down
Direct Link To This Post Topic: Murphy Bed
    Posted: 21 May 2017 at 10:21am
Almost finished with the murphy bed mod, just need to paint the underside of the bed platform. Built the bed platform up 5 inches and hinged it about 8 inches from the front wall to alow room for the mattress when lifted. Used a Cruz futon from Kmart underneath the bed, it weighs 55 pounds but was simple to install. With a half tank of fresh water there is still less than 500 pounds on the hitch.
Joe M.
Perryville, MD
Green 2017 R-pod 180
Ford Explorer Sport Trac TV
Direct Link To This Post Posted: 21 May 2017 at 11:21am
Pictures of murphy bed mod.
I started by cutting the section out of the front board for easy access to the water pump and valves.
I built the forward section to match the thickness of the futon.
I built the mattress platform from 3/8ths plywood framed with 1x6 boards for stiffness and to keep it lighter than just using thicker plywood. I used wood dowels sliding in conduit clamps to hold the bed up. I may add struts or some other way to hold it up as the valances may not be strong enough.
When raising the bed I just lift the board and squeeze the ends of the mattress past the valences and slide out the dowels. The futon back lifts up and locks in place, pull it forward then back down to close things up. The bed platform just sits on the futon pad when lowered.
Joe M.
Perryville, MD
Direct Link To This Post Posted: 21 May 2017 at 12:02pm
Nice work!
voisj View Drop Down
Direct Link To This Post Posted: 22 May 2017 at 9:57am
Clejo,
From one 180 modder to another, Nice!!
Just 1 question, I've tried lifting the mattress up and it hits the windows and valances. Did you get a little shorter mattress or still working this one out?
rgds John
SLOPODMODS
John&Sue,SLO,CA
Direct Link To This Post Posted: 22 May 2017 at 10:05am
Still have the stock mattress.  With the mattress on the platform you just need to squish the mattress in some to clear the valences and you need to have the shades up.  I built the platform to have plenty of clearance on each side.
Joe M.
Perryville, MD
rawest50 View Drop Down
Direct Link To This Post Posted: 24 May 2017 at 6:29pm
Do you have details of material and how you assembled it you are willing to share. It took me a few minutes to figure out what where the bed was. I kept looking and could not figure out how you gained space. That is nice.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler
2 Weiner dogs
Great wife puts up with my BS
❤️ Thoroughbred Racing.
Direct Link To This Post Posted: 24 May 2017 at 7:26pm
I added some details to the pictures above, it is a very simple design. The futon operation is all self contained, the back automatically locks in the up position.
Picture with mattress lowered
Futon from Kmart, just left the legs off.
Joe M.
Perryville, MD
Mirado View Drop Down
Direct Link To This Post Posted: 24 Oct 2017 at 8:38am
I like your idea.  We have a similar situation with our 181G.  After we use it a few times we'll decide if we want to mod it in some way.
D
Miriam and Doug
2015 Rpod 181G
Silverado 1500
