Page <1234> |
Ron W ![]() Newbie ![]() Joined: 26 Mar 2020 Online Status: Offline Posts: 7 |
![]() Posted: 25 Jun 2020 at 3:58pm |
Figured it out zone1 is for inside speakers turn on zone2 and outside speakers work!!
You should have some buttons on your stereo to control which speakers are on. They are probably listed as A, B, and C. Try selecting B, the most likely button for outside. C is likely not connected unless you have 3 sets of speakers. Once you confirm the speaker control buttons, if it still doesn't work, it may be that the speaker wires are not properly connected at the speakers or at the radio. Since the outdoor speakers are sealed with butyl putty, you may want to have some on hand, as well as some caulk, to reseal them if you need to remove them.
I recently bought a 2020 RPod190 and can not figure out how to get the outside speakers to work. The manual says nothing about this. It’s an furrion stereo. Anyone know how to turn the outside speakers off or on?
Danielw1 ![]() Senior Member ![]() ![]() Joined: 01 Apr 2017 Location: Oregon Online Status: Offline Posts: 115 |
I got the 4" pyramid speakers from amazon but haven't yet installed, waiting for a break in the rain. Looks like I will have to completely cut the caulking seal around the speaker surround to get at it.
Marchhall ![]() Groupie ![]() ![]() Joined: 07 May 2017 Location: Massachusetts Online Status: Offline Posts: 50 |
The sound quality of the speakers both inside and out suck. Plan on replacing both pairs after reading threads and FB to figure out what will fit and not be a huge project.
Subzilla ![]() Senior Member ![]() ![]() Joined: 23 Jan 2017 Location: Concord, NC Online Status: Offline Posts: 302 |
Yup, I wish I wouldn't have pointed out the speaker not working at the dealer. We were ready to get out of there after our big walk-thru and the technician spent 30 minutes repairing it...couldn't break the speaker loose from the box for some reason, so he pulled off the whole assembly which broke the caulking seal. He fixed the wire, remounted the assembly, and first recaulked it with white caulk. White caulk didn't match the light grey trailer or the other speaker, so he searched and found some almond colored caulk. After cleaning the white caulk off the box (sort of), he again remounted the assembly and slopped on some almond colored caulk...which still doesn't really match the other speaker caulking. We were tired and ready to hit the road so we left....again, wish I would have not said anything. Also, the TV mount was such that it was hitting the wall when trying to close and therefore, wouldn't close completely. He had already spent about 30 minutes remounting the TV. Forest River QC.
Mark
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6428 |
Agreed! It is like the outside porch light where the installer stripped one of the screws. Rather than put an anchor in, he/she drilled a third hole and added a third screw, providing another potential entry point for water if the caulking failed. The 110 outlet wasn't much better as only one end was securely attached. The other was quite loose as I could move the whole outlet by hand.
Fit and finish items are not something I go back to the dealer for though. The cost to tow it back was far greater than the cost of some simple materials to fix it myself. Paying a lot of money to get a "free" repair doesn't make sense, especially if it is something simple that I have the tools and capability to fix myself. |
One of my outside speakers wasn't working at the dealer on pickup day. The tech pulled it off and found one of the connectors was loose and barely making contact, if any. Simple stuff that could be avoided.
Mark
henryv ![]() Senior Member ![]() Joined: 09 Feb 2017 Online Status: Offline Posts: 259 |
It's disappointing that a camper with good design has so many minor problems. I took a couple of days adjusting the screen door, had to take it off and drill new holes. Today I'm fixing a piece of trim on the interior and recaulking. The quality control department needs a wake up call for sure!
cjscinta ![]() Groupie ![]() ![]() Joined: 21 Nov 2016 Location: Franklin, TN Online Status: Offline Posts: 84 |
Hey Fly Pod, Do you think these will work for replacing the interior speakers as well? How is the sound quality. The speakers inside the pod are bad. I would like to replace them but something low profile is needed otherwise you have to add spacer rings. There is a thread on the other forum regarding this.
2017 R-pod 179
Page <1234> |
