  New Posts New Posts RSS Feed: New Rpoders
Topic ClosedNew Rpoders
Direct Link To This Post Topic: New Rpoders
    Posted: 09 May 2017 at 12:41pm
Hello Todd,
Welcome and congratulations!
We have a 2016 RP-179. Ours came with neither 12V outlets nor USB outlets. They are actually easy to install. Then you can put them where you want them instead of having them where someone else thought was a good location. As for the cost, think more like a couple of bucks instead of a couple hundred. They aren't that expensive. Did they remove the USB outlets or just relocate them?
The RP-179 does NOT come with an inverter. It comes with a converter for converting 120V to 12V. This serves to charge the battery (or batteries if you have dual 6V) and to supply power to the 12V items in the 'Pod. You will need to have a battery installed as the power from the converter isn't clean enough to run some items reliably. The difference is that an inverter goes from 12V to 120V. If you want an inverter, it is something you would need to purchase separately.
For a lug wrench, the lug nuts are a standard 3/4" You should invest in a torque wrench for tightening the lug nuts. You can catch them on sale at Harbor Freight if you have one in your area for a reasonable cost. The alloy rims of the 'Pods can lead to lose lug nuts. If the wheel is removed, they need to be re-torqued after 50 miles, then after 100 miles, and then checked to make sure they stay tight. Other messages in the forum can elaborate further. As for a jack, I tried my vehicle jack once. It bent. I bought a hydraulic trolley jack at Walmart. I also made a block that allows me to jack at the riser while not putting pressure on the axle. That is important as using the axle for jacking can damage it. You can see the block in my mods, a link to which is in my signature.
Caliman View Drop Down
Direct Link To This Post Posted: 09 May 2017 at 12:08pm
Hey folks, just received our RPOD 179 after many struggles with the dealer, but ultimately it turned out well. Car and rv dealers seem to be great when selling what's on the lot, but when you want something else, they really seems to struggle. I was surprised to note that although they have improved almost every suggestion on YouTube, they have removed the USB outlets from the kitchen in our 2017 1/2. Or, did they forget to install it? I find this very odd but it must have saved them a couple hundred bucks. I also find it odd that there are no 12 volt outlets. Maybe they think their inverter is so good that these should not be necessary?
Anyway, after calling our favorite hotels a few months back, and finding the ocean view suites went from $340-to $380, I was teetering on the edge. When I discovered that we Could not book these rooms with our 8 month old and 3 year old daughters, and would have to book a different room for $450, with no ocean views, that pushed me over the fence.
Also odd that it doesn't come with a lug wrench or jack. Guess I use my car jack to change the tire? Or just call AAA. Not to try and figure out what size lugs this thing has.
Have an awesome day!!
Todd
2002 Dodge Durango 4x4 4.7 V8, BF Goodrich KO2's.
RPOD 179 with every option. RDOME
Permanent vacation!
+1, cut 4 sides, attached a top, put molding around it, stained to Pod wood (as close as I could)
Carolyn View Drop Down
Direct Link To This Post Posted: 09 May 2017 at 10:17am
Great idea. The knobs on my 2-burner are higher than the burners, so I could go to that height. Thanx so much.
Carolyn
Direct Link To This Post Posted: 09 May 2017 at 8:16am
I built one. Take a cutting board that is a little bigger than the stove. Add legs to it at the corners so it sits just above the top of the pan holders. If you get one big enough, you could make a rim all the way around and then when inverted, it becomes a serving tray.
I have pictures of the one I made in my mods (link below).
Direct Link To This Post Posted: 08 May 2017 at 2:56pm
Originally posted by Carolyn
Hello All,
Just bought "Peas-in-a-Pod" (RPod that is) and a used Honda Pilot with which to tow it. Runs wonderfully together. The other "peas" in this 'pod' are 2 elderly collies. Anyone know whether or not there is an accessorie that would cover the top of the 2-burner gas stove while we are working on the counter so as not to get the burner space messy? Can't wait to roll . . . .
This is what I have: 2 burner stove cover
Shop around, as you may find it for less.
Direct Link To This Post Posted: 08 May 2017 at 9:58am
Hello All,
Carolyn
computerfixitguy View Drop Down
Direct Link To This Post Posted: 07 May 2017 at 10:50pm
Greetings Martinmyer, pods are great and you will meet some really cool people.  Forest River will leave a reasonable mind awash in bewilderment when searching for the answer to "why did they do that" .   They are light and inexpensive.  Their attention to detail is if you peering through a hallucinating haze.  I have a 176t with the tent.  The screws were missing holding the tent in place. I know this because to repair the tent you have to remove the screws.  Its little things just like that, nothing catastrophic, just annoying.
Love my Rpod and I tell people to get one because you can buy a more expensive trailer and the trim still falls off.  They are the biggest, nicest, lightest TT you can get for the money.  Its that simple.  Bring a glue gun and some patience.  Maybe they don't use glue guns at the factory because of habitual sniffing !
They go everywhere and I laugh at others with their fully assembled trailers trying to find a camping spot big enough.
Favorite feature:  R POD people are really cool people
Derek
Kootenaypod View Drop Down
Direct Link To This Post Posted: 07 May 2017 at 10:13pm
Hi. I'm kind of a desert guy so we spend a good part of the winter in the Arizona desert. The only part of California that I have spent some time in is the Palm Springs area. Nice but a little too busy and crowded.
So if you're ever up our way, you will see nature at it's best. No tourists, no box stores, no traffic but lots of back country/mountain camp sites. We take the atv with us to really get off the beaten track.
Take care. Terry
"It good to dabble in the sewer, you will really appreciate getting out" Jerry Myers
Martinmyer View Drop Down
Direct Link To This Post Posted: 30 Apr 2017 at 8:23pm
Hi everyone! I recently purchase a second hand RP- 183 G but it need some repair so I can't use it yet. For now. I would like to know more information about owning an R-Pod so I joined this community.
