  New Posts New Posts RSS Feed: Emergency Exit Window
Topic ClosedEmergency Exit Window
henryv View Drop Down
Direct Link To This Post Topic: Emergency Exit Window
    Posted: 03 May 2017 at 7:16am
I notice the emergency exit window is different from the adjacent one. Are the little holes on the bottom designed for water drainage? Also, that one is a little tight to open..any solution? And I'm guessing in an emergency, one would raise the 2 red handles and push out. Right?
Direct Link To This Post Posted: 03 May 2017 at 8:29am
If you are talking about the slots on the bottom on the outside, yes, they are for drainage. If you look at your other windows, they should also have slots at the bottom on the outside.
In an emergency, you are correct that you raise the two red handles and push the window out. The window will pivot at the top but stay attached. You don't need to worry about it falling down onto the ground. I wouldn't open it that way regularly, but I did so to test ours. As for tightness, I'm ot sure. It may loosen up with use.
Direct Link To This Post Posted: 03 May 2017 at 11:41am
Ditto!!
Direct Link To This Post Posted: 03 May 2017 at 12:45pm
Stephen, I am NOT talking about the 2 slots on the bottom of all windows. Those are for water or condensation drainage? I was referring to two additional holes inside the slots on the emergency window only. They are triangular shaped cuts in the rubber you can see from the outside, and you can see daylight from the inside, a small hole...
Direct Link To This Post Posted: 03 May 2017 at 3:50pm
henryv,
I know what you're talking about. There are v shaped notches in the seal itself. I still haven't figured out the purpose. I can't see light thru them.
Direct Link To This Post Posted: 03 May 2017 at 7:48pm
I can't run outside and look because our 179 is at the factory for repairs. I'll have to look for those when we pick it up.
Pod People View Drop Down
Direct Link To This Post Posted: 04 May 2017 at 7:43am
We use the emergency escape window for additional ventilation.  My wife made a fabric bug screeen with velcro around the perimeter.  We open both red handles and push the window out about 8".  we prop the window open with a 8" piece of pvc conduit.  the open window provides a lot more open ventilation than when the window slides open half way.
Vann
Vann & Laura 2015 RPod 179
