  New Posts New Posts RSS Feed: New Rpod owner- Stabilizing jack question
Topic ClosedNew Rpod owner- Stabilizing jack question
Direct Link To This Post Topic: New Rpod owner- Stabilizing jack question
    Posted: 01 May 2017 at 9:30am
We have a 2009, 172 that also came with no front jacks.  For the time being, I use portable jack stands that work fine, but some time in the coming summer, I'll be installing front jacks.
As for tank water, I personally wouldn't drink it, even though I do the bleach sanitizing when un-winterizing.  We found that Simply Orange 2.7 qt. plastic bottles for drinking water.  The nice thing about them is they're essentially free, they're sturdy food grade plastic, easy to fill, and they are somewhat square so they pack well.
G. Hiker, what's the vinegar treatment that you do?
Direct Link To This Post Posted: 01 May 2017 at 1:14pm
If you sanitize your fresh water tank properly and then use an inline filter when filling your tank, why not drink it? The water is every bit as good as that which you will buy in bottles. We use a Camco TastePure filter. After buying the initial single with the flexible connector, I purchase them in the two-pack without the connector. I also purchased a 90 degree elbow to take the stress off the city water connection on the R-Pod or to connect a fill valve for filling the fresh water tank. You are already carrying 30 gallons of water. Why pack additional water just for drinking? The Simply Orange bottles you describe are no safer than a properly sanitized fresh water tank.
Direct Link To This Post Posted: 01 May 2017 at 5:12pm
Stephen - Good idea with the filter, but what does it cost for the initial purchase and cartridges and how often do you need to change them?
What I like about my orange juice bottles, is that you have high turnover of the bottles, you dump out what you don't need (in the flower pots at home, of course), you wash them at each filling (so they never sit around for too long) and you have extra water if you're dry camping.  I come from a sailboat background and the tank water in a sail boat can get pretty gnarly after not very long while sitting in the tank at the perfect bacteria growing temp.  Putting in disinfectant is always iffy because you're never really sure of how much water you have (ratio of bleach to water) and it tastes like ..... well, it doesn't taste so good.
Grandpa Hiker View Drop Down
Direct Link To This Post Posted: 01 May 2017 at 5:47pm
I got that from a "De-Winterization" checklist a couple of years ago that was poster in the R-Pod Forum. After letting the full fresh water tank sit over night with 1/2 cup of bleach, drain the tank, water lines, etc. Then refill the tank adding 1/2 cup of distilled vinegar. Open low point drains, etc. to get "vinegar water" in all pipes.
Rob & Becky
2015 R-179 Pod aka Piddle Pod
Direct Link To This Post Posted: 01 May 2017 at 7:27pm
Amazon Prime has the two pack of Camco TastePure KDF filters for $17.64. Camco says that each one will last a full season. That depends, of course, on the quality of the water being filtered. If the incoming water has more sediments, it will plug up faster and you will notice a decrease in the flow rate. When I am not using mine, I store it in the refrigerator to help keep bacteria from growing. I don't try to carry one over from one season to the next though.
Direct Link To This Post Posted: 01 May 2017 at 10:59pm
Stephen, how do you filter the water once it gets into the tank and you're pumping it to the faucet?  If I understand the Camco TastePure KDF correctly it filters the water from the fill hose to the tank or to connection to the hose fitting for domestic pressure water, bypassing the tank and pump.
It's what grows in the tank once you put the water in it that makes me a little squeamish.  Are there inline filters that you can put near the galley sink that will filter just the water for the sink faucet but will not have such flow resistance that it may hurt the pump?
Direct Link To This Post Posted: 02 May 2017 at 9:27am
I don't filter the water again. Between trips, I don't leave the tank full. I have seen some inline filters that could tap into the cold water line with filtered water having a separate faucet. I think that is overkill though. If you are really worried, sanitize the tank before every trip. Otherwise, once a season at the beginning should be fine.
Another alternative is to use a pitcher filter such as a Brita or Pur pitcher. That would not require any plumbing modifications and would certainly be less expensive than the under-sink filter. A third alternative is to use a faucet mount filter such as one from Pur, Brita, or DuPont. I would not worry about hurting the pump. It will cycle on and off as needed to maintain pressure. If the flow is restricted, it will not try to keep forcing more pressure. It will just cycle.
Direct Link To This Post Posted: 02 May 2017 at 11:43am
Thanks for the info, Stephen.  For me, being retired, I'm a little on the lazy side and what you propose seems like an awful lot of work.  I think I'll stick to my orange juice bottles for drinking water.  ðŸ˜Ž  I never use the paper cups to drink water in the airplane heads either.  It' not that I don't have faith in United, but ...........
Live2Camp View Drop Down
Direct Link To This Post Posted: 02 May 2017 at 3:11pm
I know I will never be able to go camping without jugs of water, even if the RPod tank is full. But whether or not you fill it, I agree with those who advise to clean the system anyway. You never know when you might want it in the future, and it will be easier to get it ready for potable water if you've been maintaining it all along. Hope this helps.
His:Ford F150 double cab 4WD; Hers/mine:Tacoma V6 double cab 4WD
Still love rugged, diggin' comfy too
