  New Posts New Posts RSS Feed: Heater use when Boondocking
Topic ClosedHeater use when Boondocking - Event Date: 24 Apr 2017
MDPaddlersPod View Drop Down
Direct Link To This Post Calendar Event: Heater use when Boondocking
    Posted: 24 Apr 2017 at 4:13pm
I have not done any boondocking yet but, plan to this year. I am wondering how you run the heater in the Pod at night when you shut the generator off for quiet hours. Will the batteries run it through the night?
MDPaddlersPod
2017 RPod 179
2002 Silverado1500
CharlieM View Drop Down
Direct Link To This Post Posted: 24 Apr 2017 at 4:29pm
The onboard furnace uses propane for the heat and 12V for the fan. The fan draws 3.4A while it's running. A fully charged Gp24 battery will easily run it for a night if it's not well below freezing. A pair of 6V golfers will go for several days.
Direct Link To This Post Posted: 24 Apr 2017 at 6:42pm
+1
Direct Link To This Post Posted: 24 Apr 2017 at 7:16pm
+2
Direct Link To This Post Posted: 24 Apr 2017 at 8:27pm
We do a lot of camping in the shoulder months of April-May and September-October so our furnace gets used a lot.  Probably the best test is when we are in Glacier or RMNP where there is no electricity and we use our batteries.  Night temps are normally in the mid to upper 40's at night, sometimes a bit cooler.  We expect to get 3 - 3.5 days from each battery.  Our batteries are 12 v group size 24  deep cycle and are beggining year 7.  When they expire we will probably go with 2  6volt golf cart batteries.
john in idaho View Drop Down
Direct Link To This Post Posted: 25 Apr 2017 at 9:08am
We use flannel lined sleeping bags, and turn the furnace off until around 6 in the morning then switch it on and start the coffee percolator.
Direct Link To This Post Posted: 25 Apr 2017 at 9:20am
Thanks to everyone for the responses, I really appreciate it.
MDPaddlersPod
2017 RPod 179
2002 Silverado1500
Direct Link To This Post Posted: 25 Apr 2017 at 9:45pm
I usually turn the thermostat down to about 60 degrees when we go to bed and turn it up in the morning when I get up since I get up before my wife. On our last trip, I picked up a Mr. Buddy Portable. Since I don't have the hose to adapt it to a tank yet, I only use it to take the chill off quickly as those 1-lb tanks can get expensive.
podenvy View Drop Down
Direct Link To This Post Posted: 26 Apr 2017 at 4:06am
The heater is a propane hog, while the fridge will sip at the propane tank. We slide the main window open a bit and open the bathroom vent so there's air circulating with the heater on, but be prepared for moisture in the morning.
2013 FJ Cruiser + 2015 rpod 179 HRE
