Page 12> |
PodWa ![]() Newbie ![]() ![]() Joined: 11 Oct 2016 Location: Cheney, WA Online Status: Offline Posts: 36 |
![]() Posted: 24 Apr 2017 at 10:10am |
We had good water flow in the bathroom of our 2017 RP179, but very weak flow at the kitchen sink. I removed and disassembled the screen filter on the faucet to check for debris. Yes, I found some. I also found three screen disks stacked one upon the other in the filter unit. Could this have been intentional? No wonder water flow was restricted! I cleaned the filter and removed two of the screens. Now water flow is restored! Hope this saves someone a little time and trouble.
john in idaho ![]() Senior Member ![]() ![]() Joined: 04 Nov 2014 Location: Eagle Idaho Online Status: Offline Posts: 613 |
The good part is that you now have 2 spares.
The stacking of the screens IS intentional.When living with a 30gallon holding tank, limiting flow is a plus. If you always camp with FHU's.. then not an issue.
Thanks, FurPod! That makes sense. Perhaps, the combination of the three screens and a little debris caused water flow to slow to a trickle. I might try the screens again.
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3366 |
I noted that we have 3 screens in ours as well. Since our well water is very clear, and we don't use anyone else's water, we have never had an issue with the screens plugging up. I do check them however once/year just to make sure.
gunny ![]() Newbie ![]() ![]() Joined: 04 Oct 2016 Location: portland oregon Online Status: Offline Posts: 6 |
Thank you for your post. I went out and checked my 177, and i had 4 screens.
Why would they do that. |
I think FurPod got it right...they are there to partially restrict flow to limit water use and keep the grey water tank From filling too quickly. Our water flow at the sink had slowed to only a small trickle which caused me to check the screens. I originally removed two of the three screens, but replaced them after FurPod's analysis. Now I have acceptable, but somewhat restricted flow. I guess that it does not take much debris and three screens to really slow the flow.
When in a full service campground, not worried about gray tank filling. When truly boondocking, I do my dishes in a pan or use the outside shower faucet for light clean up. My experience has been the water pressure is more dependent upon the water pressure from the spigot, and if that is to low I fill the fresh water tank and use the water pump. I look for 45lbs when I set up. I took my faucet apart after this post, it has one screen.
PilotPodder ![]() Senior Member ![]() ![]() Joined: 04 May 2016 Location: Portage, MI Online Status: Offline Posts: 305 |
Thanks for posting this. Just ran into this same problem on my new 179 while out camping. Pulled the screen apart and found considerable construction debris causing obstructions! Much better now.
Fredness ![]() Newbie ![]() ![]() Joined: 04 May 2016 Location: Fredland Online Status: Offline Posts: 1 |
The "debris" is chunks from you zinc anode in the water heater.
Might want to check that... And flush the water heater with a wand. |
Page 12> |
