coopercdrkey ![]() podders Helping podders - pHp ![]() ![]() Joined: 26 Aug 2012 Location: Cedar Key, FL Online Status: Offline Posts: 457 |
![]() Posted: 11 Apr 2017 at 6:24am |
Just coincidently, as I exchanged my regular hitch for the load distributing one in preparation for a trip, I noticed that the hitch ball would rotate pretty freely in my hand. Wow! what a potential disaster in the making! A couple of big wrenches solved the problem in a minute, but it could have been hours of frustration or worse.
Be careful out there...
Bob and Joyce
Jennifer and Baxter, the Campin' Cocker Spaniels RP 177 "Key Pod" Chevrolet Silverado 1500 LT / Z71 |
Great tip!
ToolmanJohn ![]() Senior Member ![]() Joined: 23 Apr 2014 Location: Connecticut Online Status: Offline Posts: 451 |
Hope you applied some thread locker before re tightening. RED thread locker would do it.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6428 |
Also hope you had a large enough torque wrench to torque it to manufacturer's specifications. For example, the ball on the Equal-i-zer hitch we have needs to be torqued to 430 ft-lbs with the bolts that hold the head to the shank requiring 300-350 ft-lbs. See http://www.equalizerhitch.com/Equal-i-zer%20Support/faqs.php for more details. I don't know the brand of hitch, but please refer to the manufacturer's specifications, whatever the brand.
Rustler ![]() Senior Member ![]() ![]() Joined: 07 May 2016 Location: S. Oregon Coast Online Status: Offline Posts: 100 |
That's a good reminder to have the attachments torqued to manufacturer's specs. Lacking a proper high capacity torque wrench, I have made a poor man's torque wrench by putting a long "cheater bar" on a regular breaker bar and socket. So with a 5 foot long bar and and a 86 lb. pull you'll get 430 foot-lbs. of torque (86 x 5 = 430). Just measure the pull on the end of the cheater bar with a 100-lb. capacity spring scale. Pull on the support end of the scale until the scale reads 86 lbs. and you'll get the required torque. It may require having some help to hold everything in place on the nut while you are pulling on the scale. While you might take the hitch part to a dealer to have them torque the nut, how many will really have a torque wrench capable of measuring 430 foot-lbs. They'll just get it as tight as possible as say it's done to specs.
Russ
2009 Toyota RAV4 V6 w/ tow package 2016 Rpod 171 HRE |
Danielw1 ![]() Senior Member ![]() ![]() Joined: 01 Apr 2017 Location: Oregon Online Status: Offline Posts: 115 |
That sounds like a lot of whatnot to get a nut tight! Reef on it with a big wrench and weld the nut. This also will act as a deterrent for thieves if they ever tryed to steal your trailer.
That's a good reminder to have the attachments torqued to manufacturer's specs. Lacking a proper high capacity torque wrench, I have made a poor man's torque wrench by putting a long "cheater bar" on a regular breaker bar and socket. So with a 5 foot long bar and and a 86 lb. pull you'll get 430 foot-lbs. of torque (86 x 5 = 430). Just measure the pull on the end of the cheater bar with a 100-lb. capacity spring scale. Pull on the support end of the scale until the scale reads 86 lbs. and you'll get the required torque. It may require having some help to hold everything in place on the nut while you are pulling on the scale. While you might take the hitch part to a dealer to have them torque the nut, how many will really have a torque wrench capable of measuring 430 foot-lbs. They'll just get it as tight as possible as say it's done to specs. [/QUOTE]
I use the same method but, not as scientific. Last time, I tightened until the rear wheels of the truck began scooting sideways on the asphalt. My watching neighbor agreed that it was probably tight enough! ![]() Who was it that said: "Give me a lever long enough and I will move.....the back of a pickup truck"??? |
[That sounds like a lot of whatnot to get a nut tight! Reef on it with a big wrench and weld the nut. This also will act as a deterrent for thieves of the ever tryed to steal your trailer. ]
I like that!!!
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3345 |
Great reminder. In fact after reading that I took my Reece hitch to work to see if it was a bit loose. I took our 5 ft. pipe wrench and put the hitch in the vise. Not able to move it at all, guess it is still tight after 6 years.
malkbean2 ![]() Groupie ![]() Joined: 31 Jan 2017 Online Status: Offline Posts: 80 |
i torque as tight as humanly possible then tighten a second nut on it to lock it down
