  New Posts New Posts RSS Feed: Solar Power
Topic ClosedSolar Power
sylviablue View Drop Down
Direct Link To This Post Topic: Solar Power
    Posted: 18 Jan 2010 at 7:39pm
Any price on that set up?
four peas
TerryM View Drop Down
Direct Link To This Post Posted: 18 Jan 2010 at 12:56pm
Make a list of what you would be running.  On that list put on the power consumption per hour of use.  Total them up and compare it to the solar panel setup.
Terry
Edit: if you run into problems or just have any technical questions talk to John Palmer.  He lives off the power grid!   Go here: http://www.palmerenergysystems.com
rpodcamper.com View Drop Down
Direct Link To This Post Posted: 18 Jan 2010 at 10:29am
I'm looking to power Lights, and water pump.  No AC, Microwave or TV.
Direct Link To This Post Posted: 18 Jan 2010 at 10:24am
Here is the photo
GrandPod View Drop Down
Direct Link To This Post Posted: 18 Jan 2010 at 10:22am
 You also need a charge controller. A inverter uses alot of current; I'd think if you could use 12 vdc appliances you'd be better off.
 Tom
Tom and Linda
R-Pod 177
Southwest Florida
rpodadmin View Drop Down
Direct Link To This Post Posted: 18 Jan 2010 at 10:00am
any photos?
Direct Link To This Post Posted: 18 Jan 2010 at 9:57am
I was out looking today and wondering how this would work at keeping my batteries charged as we dry camp:
45 Watt Solar Panel Kit
Use the sun's power to run TVs, lights, computers and recharge 12VDC batteries!
  • Three 15 watt solar panels give you plenty of clean, quiet energy - no fuel required
  • Power center is completely weatherproof and works under all light conditions
  • 3, 6, 9, 12 volt DC adapter outlets
  • Easy-to-read LED charge indicator
  • Includes mounting hardware, light, 12V socket and battery clamps
Requires 12 volt storage battery and 300 watt power inverter (not included). Maximum current, 3000 mA. 15 watts max per panel. Peak voltage: 23.57 volts open current. Panel dimensions: 12.40'' x 36.42'' x 0.75''
Weight: 9.7 lbs.
