  New Posts New Posts RSS Feed: Water Leaks
Topic ClosedWater Leaks
Direct Link To This Post Topic: Water Leaks
    Posted: 12 Apr 2017 at 5:50pm
Warning stickers are a pain. I had a new garage door installed and they put warning stickers everywhere! I took them off.
Direct Link To This Post Posted: 12 Apr 2017 at 3:57pm
The burner may take more then 3 cycles to start if the lines need to be purged..
and to be clear.. these are PLUMBING leaks, not roof, vent, etc leaks?
Plumbing tightening is an ongoing maintenance item for travel trailers. They move and shift while going down the road.
Bugout View Drop Down
Direct Link To This Post Posted: 12 Apr 2017 at 3:40pm
Open the water heater relief valve to see if it's got water in it .if not onen the bypass valve
Jk Aiken South Carolina 2016 178 Toyota Tundra 2017 4.6
TeeBrock View Drop Down
Direct Link To This Post Posted: 12 Apr 2017 at 3:14pm
I have been working on the leaks. The major problem was probably from a fitting that was loose in the exterior shower. I re-leveled the unit to run to the exterior if something else would leak. On Monday the water heater wouldn't work. I did some troubleshooting and tapped on regulator, then changed out LP tanks. I believe it's the ignitor as the burner fails to light on the 3 consecutive starts.
I have an appointment at a dealership tomorrow.
One really irritating thing is the inconsiderate placing of the warning stickers. One was stuck (partially) to my door and it caused the graphic to rip. Very unappealing.Confused
Direct Link To This Post Posted: 12 Apr 2017 at 10:36am
again, what kind of leaks, and where?
we can't help you with dealer issues, BUT we can help you battle leaks if needed. Since the pod is surely still under warranty, have you talked with your dealer?
Direct Link To This Post Posted: 12 Apr 2017 at 8:04am
I have a copy of the checklist with VIN, my information and dealer info. This is my second RV (I purchased a WolfPup last Aug., but did not like it) in 8 months from the same dealer. Apparently, this form is not used as I, too expected. There has never been 1 box of either checklist, checked off. I asked about it with the previous one, but it was not addressed as that was the last packet given to me as I was out the door.
(Both were 2017 models with the RP 180 being the 2017 1/2)
Podster View Drop Down
Direct Link To This Post Posted: 12 Apr 2017 at 7:41am
Water leaks? Pluming or shell integrity?
All dealers should be using a predetermined prep and delivery checklist under the Pre-Delivery Inspection (DPI) program. You may have a copy in your purchase packet. If not, ask you dealer for a copy.
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 11 Apr 2017 at 10:00pm
I have had my RP 180 for 8 weeks and have had multiple water leaks. Does anyone know what the Manufacturer actually does vs. what the dealership prep involves?
Tee
