Page 12> |
rawest50 ![]() Senior Member ![]() ![]() Joined: 07 Mar 2017 Location: Arkansas Online Status: Offline Posts: 440 |
![]() Posted: 29 Mar 2017 at 5:58pm |
Recommendations for mounting various shelves, hangers, etc. to the interior walls and the exterior walls. Screws & length? Know I can use Velcro tape.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler 2017 Chevy Colorado Z71 Off Road Crew Cab 2 Weiner dogs Great wife puts up with my BS ❤️ Thoroughbred Racing. ![]() |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6437 |
Any screw or anchor needs to be 1" or less. Anything more will go through.
Thanks. Was that answer from experience?
2017.5 RPod 179
Yes, unfortunately.
john in idaho ![]() Senior Member ![]() ![]() Joined: 04 Nov 2014 Location: Eagle Idaho Online Status: Offline Posts: 613 |
When i added a window to the door on our 179, I saved the piece i cut out. Two thin plastic/fiberglass walls filled with styrofoam . If you are drilling a hole, use VERY gentle pressure, or you might be looking at a drill bit on the outside of the pod.
We've used these anchors with great results on the thin paneling of the inner walls:
http://www.homedepot.com/p/Hilti-3-16-in-HTB-Toggler-Bolts-with-Philips-Flat-Head-Screw-8-Pack-3512330/204992998 |
Also recommend when drilling from outside or inside, use a drill bit stop or piece of tape around bit to control depth, a stop set is available from Lowe's, less than 8 bucks.
I used the exact anchor for my TV bracket in our bedroom. Easy and worked great.
2017.5 RPod 179
riotkayak284 ![]() Senior Member ![]() Joined: 29 Apr 2016 Location: Nashville, TN Online Status: Offline Posts: 162 |
I prefer these things to anything...
http://www.command.com/3M/en_US/command/ |
We've had mixed success with Command products. The problem is that the walls are so slick that the adhesive doesn't hold very long. |
Page 12> |
