  New Posts New Posts RSS Feed: Mounting to the walls. Inside & Out.
Topic ClosedMounting to the walls. Inside & Out. - Event Date: 01 Apr 2017
rawest50 View Drop Down
Direct Link To This Post Calendar Event: Mounting to the walls. Inside & Out.
    Posted: 29 Mar 2017 at 5:58pm
Recommendations for mounting various shelves, hangers, etc. to the interior walls and the exterior walls. Screws & length? Know I can use Velcro tape.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler
2 Weiner dogs
Great wife puts up with my BS
❤️ Thoroughbred Racing.
Direct Link To This Post Posted: 29 Mar 2017 at 9:10pm
Any screw or anchor needs to be 1" or less. Anything more will go through.
Direct Link To This Post Posted: 29 Mar 2017 at 11:03pm
Thanks. Was that answer from experience?
2017.5 RPod 179
2 Weiner dogs
Direct Link To This Post Posted: 30 Mar 2017 at 8:21am
Yes, unfortunately. Pinch  I tried using a "short" moly bolt which turned out to be too long. I have a reminder to not do that again. I plugged the hole with a green cover and sealant. Until our 'Pod is taken to be repaired from last year's accident, I see it every time I go outside and look at that side.
john in idaho View Drop Down
Direct Link To This Post Posted: 30 Mar 2017 at 9:31am
When i added a window to the door on our 179, I saved the piece i cut out.  Two thin plastic/fiberglass walls filled with styrofoam .  If you are drilling a hole, use VERY gentle pressure, or you might be looking at a drill bit on the outside of the pod.
TheBum View Drop Down
Direct Link To This Post Posted: 30 Mar 2017 at 11:27am
We've used these anchors with great results on the thin paneling of the inner walls:
http://www.homedepot.com/p/Hilti-3-16-in-HTB-Toggler-Bolts-with-Philips-Flat-Head-Screw-8-Pack-3512330/204992998
Direct Link To This Post Posted: 30 Mar 2017 at 11:41am
Also recommend when drilling from outside or inside, use a drill bit stop or piece of tape around bit to control depth, a stop set is available from Lowe's, less than 8 bucks.
Direct Link To This Post Posted: 30 Mar 2017 at 12:02pm
I used the exact anchor for my TV bracket in our bedroom. Easy and worked great.
2017.5 RPod 179
2 Weiner dogs
riotkayak284 View Drop Down
Direct Link To This Post Posted: 30 Mar 2017 at 12:38pm
I prefer these things to anything...
http://www.command.com/3M/en_US/command/
Direct Link To This Post Posted: 30 Mar 2017 at 12:58pm
Originally posted by riotkayak284
I prefer these things to anything...http://www.command.com/3M/en_US/command/
We've had mixed success with Command products. The problem is that the walls are so slick that the adhesive doesn't hold very long.
