  New Posts New Posts RSS Feed: Replacing Bat Wing antenna
Topic ClosedReplacing Bat Wing antenna - Event Date: 07 Mar 2017
TheBum View Drop Down
Direct Link To This Post Calendar Event: Replacing Bat Wing antenna
    Posted: 08 Mar 2017 at 2:42pm
After I posted, I thought of rigging up a stepper motor controlled by a potentiometer mounted to the wall. The stepper would turn the knob in response to turning the pot. The mod would also require bringing out the signal strength indicator lights to where they could be seen.
Direct Link To This Post Posted: 07 Mar 2017 at 7:55pm
An alternative to moving the antenna would be to cut an opening through which the antenna's controls could be reached and worked. It might involve relocating the items that would be in the way (outlet, antenna booster, etc. If you have any skill in making this type of modification, it might be a viable option.
Podster View Drop Down
Direct Link To This Post Posted: 07 Mar 2017 at 7:19pm
You might get a signal acquisition performance bump if one of the bat ears is now vertical. Smile
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 07 Mar 2017 at 11:58am
If I were to replace the antenna in our 179, I'd get a King Jack antenna and not another omni-delusional antenna (an omnidirectional antenna only guarantees that you'll get bad reception in all directions). Unfortunately, it would also mean moving the location of the antenna because the directional knob would be in the airspace behind the stereo otherwise. I've actually considered doing this, but with DIRECTV NOW streaming over AT&T wireless, my interest in doing so has waned.
P and D Podders View Drop Down
Direct Link To This Post Posted: 07 Mar 2017 at 10:56am
The batwing antenna on my 179 has bent and needs replacing.  I was looking at a King Omnipro, omni directional antenna as a replacement.  Have any of you had any experience with this antenna?  Have any of you replaced your batwing with one of these?  Is there anything I need to know before I buy and install one of these?
P and D Podders
