voisj
Topic: Texman 182g Mods Posted: 19 Apr 2017 at 4:02pm |
Texman,I like the way you did the latch,the mounting and the horizontal piece under the front edge,nice mods to the table!
SLOPODMODS
John&Sue,SLO,CA
texman
Posted: 17 Apr 2017 at 10:21am |
texman
Posted: 10 Apr 2017 at 11:22am |
making progress on the side table. Thanks to John and Sue for this idea. The 182g internal framing is a real challenge when trying to do this mod. I used a 1" aluminum tubing for my trailer and shelf attachment piece for strength since i only have three attachment point to the trailer over 83". I used 1/4" nut inserts into the pod at these points. Also- apparently the studs in the walls are of an s shape. i cant tell. But the studfinder and the exterior moisture test revealed studs, but a 1/8" test hole was contraindicated, to say the obvious. i was glad i drilled very small test holes to verify the stud location before the big 13/32" bore. The table is made from redwood 2x6 cut into 3/4" pieces and biscuit joined. a buddy planed it for me and the side you see is the ugly side that needs a little sanding. The top looks much better. started staining last night. The table is exactly 12" wide and 80.5" long. it fits under the window trim with about a 1/8" to spare. My plan is to support the table by using some of the 1.5" redwood strips that diagonal from the outer edge to the c channel at the bottom of the pod. The way the studs worked out, i have to go below, because of the handle on the door.
texman
Posted: 10 Mar 2017 at 8:49am |
My Favorite $16 mod. Double light over the sink. Wow-what a diference.
texman
Posted: 09 Mar 2017 at 8:38am |
Leo B
Posted: 07 Mar 2017 at 4:47pm |
Trade ya, we have 34 degrees
texman
Posted: 07 Mar 2017 at 3:09pm |
at least your aren't on fire!
Alloy89
Posted: 07 Mar 2017 at 3:00pm |
Well it's cold today here in San Antonio too, 71 degrees!
Alloy89
Posted: 07 Mar 2017 at 2:59pm |
texman
Posted: 07 Mar 2017 at 2:53pm |
Frozen Tundra of Texas-Amarillo
