  New Posts New Posts RSS Feed: Texman 182g Mods
Topic ClosedTexman 182g Mods
 Post Reply Post Reply Page  <1 2425262728 33>
Alloy89 View Drop Down
Direct Link To This Post Topic: Texman 182g Mods
    Posted: 07 Mar 2017 at 2:52pm
TexMan, got and please let us know how it works for you after your next trip. Also I'm in San Antonio where in Texas are you located (based on ur handle)?
texman View Drop Down
Direct Link To This Post Posted: 07 Mar 2017 at 2:46pm
Alloy
i just did the mod and haven't used it.  I added a cleanout for the gray line at the 90 deg turn, if you can see it. The cleanout was a recommendation of the person that i stole this from to wash the line out of food and such.  Not sure if you can tell from the photos, but the line i added to connect the tanks does have decent fall to it, about 2" over 6.5 feet, so that should drain good.
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 07 Mar 2017 at 2:02pm
TexMan, I'm looking to get a 182G in the next few months and was wondering if you have heard any pro or cons on the Gray Tank drain mod?  It looks pretty easy and having just one hose connection location would be great. Any issues with the gray water not properly draining after the mod? Thanks and love all your great Mods! Tony
Direct Link To This Post Posted: 07 Mar 2017 at 8:41am
new sewer valve and a cleanout for the gray line as well.
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 07 Mar 2017 at 8:38am
mounted the 2 gallon pressure tank.
snug as a bug in a rug.
TexMan 2015 182g
2018 Sequoia
TexManMods
SC for Huskers View Drop Down
Direct Link To This Post Posted: 02 Mar 2017 at 2:05pm
got it
Thanks, now off to Advance Auto or Auto zone.
Happy Traveling,
Tom
2017 172pod
2011 F150 STX
Direct Link To This Post Posted: 02 Mar 2017 at 1:25pm
SC
This is for parallel not series.  this is to isolate the solar from the pod. do, if switch is on 2, you can only charge the batteries and the pod is off, no drain.  1 and 2 pod and zamp both.  off is all off, batteries isolated.
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 02 Mar 2017 at 1:22pm
Thanks, I'll check, but think it is 10 gauge. As for alternator, don't know, We do know it can take care of 1995 F150 6 and the original Pod's excide. Before any alterations, need to check on that. I know it is 1 yr old life time warranty
Again, thanks for your help, Ill look up the switch and maybe there is a schematic of how to hook it up.
Later,
Happy Traveling,
Tom
2017 172pod
2011 F150 STX
Direct Link To This Post Posted: 02 Mar 2017 at 1:08pm
Originally posted by SC for Huskers
I don't understand why the two 12 deep cycle didn't charge while driving? Now I'm worried, heading out for first trip, and have replaced the excide battery with 2 sears deep cycle, style 24 in parallel. I was told by the dealer my truck will keep them charged. Is there any way you can show me how to hook up the battery switch you got and where you get it? I think you can email me. Thanks
Reasons why the batteries may not have charged:
1. If you were running the refrigerator on 12V while driving, the power required for that may have meant that there was not sufficient left over to charge the batteries. Cure: Run refrigerator on gas while moving and on AC when connected to shore power.
2. Charging wire of insufficient gauge to carry enough current to charge the batteries. 10 gauge wire is the smallest size that should be used. If available, 8 gauge would be better.
3. Alternator is not putting out sufficient Amperage to meet the needs of both the truck and the R-Pod.
4. Despite dealer's assurance, the 12V supply to the trailer might have a problem. Use a good digital voltmeter to check the trailer connector to see if it has 12V power. There could be a blown or missing fuse.
Check this diagram for the pinout on the Bargman Connector. Use the #4 and #1 connections to check.
Direct Link To This Post Posted: 02 Mar 2017 at 11:48am
I have a battery charger on them now, and after 30min went to full charge, left on 5 amp overnight. No, I plan on using gas for frig. from Charleston to Perry GA. ( 6hrs max) if I have to, then change over to shore power then go shoping while frig is getting cold. (GA fairgrounds, stores near) ,. I don't know how the charge is kept on the battery,(not that far in the book) but do have 2 solar units that I can run. (again haven't read that far) Still trying to basics like Twin bed, sheets, caulks, hoses with fittings. Got to two battery boxes and batteries ( gel type). Got a quick disconnect for the batteries, but not a switch that you are talking about. Again, can you tell me how to hook it up, if will find it on amazon. don't know how to get an email of a diagram? Thanks for your help. I figured out how to the Iball, and back up under hitch, now for how to back the trailer with the same unit. like I said first time, but this battery thing has thrown me.
Happy Traveling,
Tom
2017 172pod
2011 F150 STX
