Page <1234> |
GlibGuy ![]() Groupie ![]() ![]() Joined: 14 Apr 2015 Location: Virginia Online Status: Offline Posts: 65 |
![]() Posted: 26 Feb 2017 at 9:57am |
I would be interested in a couple of these IF. Does that snout fit down into the fresh water intake? If yes, what are they called and where did you get them? I haven't done an intensive search but I'm not coming up with anything. (I agree I'm probably over concerned about weight but I could use a couple of these when I'm on extended primitive camping.) Thanks!
MICK
hogone ![]() Senior Member ![]() ![]() Joined: 09 Apr 2013 Location: High Ridge, MO Online Status: Offline Posts: 1060 |
ya, i like these!! hogone
Jon & Pam
2013 RP177 2023 F150 2017 HD Streetglide CHEESEHEAD |
Those are pretty efficient looking!
voisj ![]() Senior Member ![]() Joined: 19 Jul 2016 Location: San Luis Obispo Online Status: Offline Posts: 471 |
GlibGuy, Hogone, & leo,
Any motorsports store, (think motorcycle ATV). Yes, the hose fits down the fresh water filler. I put the stuff on top, (on/off valve and hose) myself, It comes with a large cap with a 3/4 " plug on top, I removed the plug and put the attachments in the plug hole. It's best if you go to the store and play with them, some are more ergonomic than others with the handle on one side and the breather cap next to it. It's 45 lbs full and if its not easy to hold it's a pain while filling. here's a link Rgds John
The only problem I see is that these are not made for potable water. That means that they might leach chemicals into the water. I would prefer one that is made for potable water. On our winter trip, we used this one which we got at our local Wal-Mart:
Reliance Products Hydroller 8 Gallon wheeled water container The local store price may be higher than the online price. With the proper fittings, this could be adapted to a hose which could then be used to fill the R-Pod's tank. |
If we do a short weekend trip we bring 10 gallons of well water with us. Yes, we did the math, takes 40 seconds to fill a 5 gallon bucket so. . . . . put the hose in the hose filler and let it run for 80 seconds and we are done. Longer trips we always fill to the max before leaving. Rather not have to put city/ municipal water in our tanks, don't care for the taste or the chemicals in them. Actually we have always had well water in our tanks and on the advice of furpod did indeed sanitize our tanks for the first time last year after owning our 177 for 5 years.
Thanks for all the good posts. I plunged ahead and ordered the "LC" 5 gallon jug with hose from MotoSport. I may order another if I'm happy with their product
As far as whether the product keeps water potable, I usually camp alone and carry water separately for drinking, cooking (don't do much) and personal hygiene (other than showers). Great folks on this forum!
MICK
I use one of these upstream of the water filter.
https://www.amazon.com/gp/product/B0058EOC5M/ There's so little water contact with plastic that any chemicals that might leech into the water would be insignificant. |
Here's a 6 gallon water can that is bpa free and only $14 at online, (+$6 shipping). The handles look good and would work for easy pouring. I don't see an air vent though which makes a huge difference when your holding 50lbs.
http://www.tooltopia.com/null-mwc6700.aspx?utm_source=google&utm_medium=cpc&utm_campaign=paid_search_google_pla&scid=scplpMWC6700&sc_intid=MWC6700&gclid=CjwKEAiAuc_FBRD7_JCM3NSY92wSJABbVoxBCLEbZaC7UB2c6WKBl9itq9FlxpLUhc-Xotg0cwtDzBoCdx3w_wcB
I don't cook with or drink water from the fresh water tank, but i do understand potable water containers are a better option. My LC 2 is left empty until I travel and then keep out of the sun under a shell in the back of my truck while traveling, Long term storage freezing and/or storage in the sun could be an issue. From the study i just read, " If you are using a plastic water bottle, you should avoid drinking from any that have been frozen and/or exposed to sunlight or high temperatures". |
Two comments, largely based on previous posts. Freshwater tank capacity is 36 gals. That is roughly close to 300 lbs. That weight negates tongue weight. The aft water tank is on the other side of the axle, the fulcrum. It is possible to decrease tongue weight to the point where sway is significantly increased. From my experience there is a larger amount of sway with full water tank and no sway control. I don't tow without sway control, so for all purposes I can cover the weight. Comment 2 - I urge you if you haven't to inspect your tank holding crossbars. The unwelded ones are held on by #14 sheet metal screws. Some have found these screws to be pulling out or missing. Tanks have fallen out of TTs. Also make sure your securing cross bracket goes all the way to the frame rail, not screwed on with a gap. Some of us have bolted out brackets thru the frame, eliminating the screw loosening issue. Thanks.
Page <1234> |
