puudged
Calendar Event: Solar, 12volt questions Posted: 21 Jan 2017 at 7:27pm |
LOL, I will make sure my geekies know what they are doing😫 My main go to guy installs electronics in fire engines and police vehicles... Cross my fingers that he knows what he is doing:) Thanks again for helping me out!
Podster
Posted: 22 Jan 2017 at 7:51am |
Originally posted by mcarter
Podster,
Comparing notes. Where did you mount yours in 178? I mounted mine in the panel, near door, that is the dinette passenger seat. I can open door and look at 12v status and use USB and 12v charge with device resting on dinette cushion or table. Drilled a hole thru floor of front storage compartment, and ran 14 gauge wire into floor of electrics bay and used spare fuse for connection point. Works great, silicone holes and secured wiring below TT and in front storage area. From what I have seen the 179 is much easier to access. |
I try to use what I call the service panel for all things utility...
Here is a pic...
Cliff & Raelynn
Ranger 4.0/178
Podster
Posted: 22 Jan 2017 at 7:55am |
Yes, sounds like you have a good geek there.
Cliff & Raelynn
Ranger 4.0/178
Posted: 22 Jan 2017 at 9:28am |
P=I X E Ohms Law. I this case power = 20 amps X 12 volts or 240 watts. With the line loss inherent with low voltage DC don't plan on much from that solar install.
2011 R-Pod 177
2010 Ford F-150
Podster
Posted: 22 Jan 2017 at 9:31am |
What solar install are you referring to?
Cliff & Raelynn
Ranger 4.0/178
CharlieM
Posted: 22 Jan 2017 at 11:10am |
| Not clear what you are saying here. Twenty amps for a typical 5 hour sunny day gives you 100 AH which is 3-6 times the typical camper's usage.
Posted: 22 Jan 2017 at 1:22pm |
Cool, thanks.
