  New Posts New Posts RSS Feed: Towing Capacity
Topic ClosedTowing Capacity
birderdiane526 View Drop Down
Direct Link To This Post Topic: Towing Capacity
    Posted: 11 Jan 2017 at 3:19pm
What is the general consensus about towing weight meeting your TV's capacity. Our 4Runner has a 5000 lbs tow capacity. Would it be dangerous to tow 5000 lbs behind us?
Thanks for your help.
Diane and Michael
2007 Toyota Tundra
BLOG:Podding in Paradise,
birderdiane526.blogspot.com
Direct Link To This Post Posted: 11 Jan 2017 at 3:54pm
I wouldn't go more than 80 %.
Direct Link To This Post Posted: 11 Jan 2017 at 4:20pm
Personally, I consider 5K capacity about the minimum for towing a Pod, or something of similar weight. If the budget allows, I'd like to see you in something "full size" and a V8.
An "old timer', years ago, told me to "have a tow vehicle that is rated for twice the amount of the actual tow weight, and you'll do OK". He was pretty smart!
Following his advise, you would want something rated to tow 10K lbs. (or close to it).
You could get down the road with what you have but, I'm not sure how pleasant or safe the experience would be....you would be at the max.
Direct Link To This Post Posted: 11 Jan 2017 at 4:22pm
Thank you David and Marwayne! Good info.
Diane and Michael
2007 Toyota Tundra
ToolmanJohn View Drop Down
Direct Link To This Post Posted: 11 Jan 2017 at 4:31pm
birderdiane526 , As long as everything is correct (4Runner Payload 1255-1295 lbs depending on 2wd-4wd and model) you should be plenty saf. You have to subtract the weight in the 4Runner from the payload capacity, then the tongue weight from the payload capacity. Don't exceed 12XX lbs interior payload capacity(people, cargo, tongue weight).
 If you tow max trailer weight assume 10% tongue is safe (can't find max tongue on the 4Runner receiver, but it might be 500lbs because the stock receiver is a rear cross member mounted one, not a frame mounted one.) Frame mounted OE receiver (was available for the V8 and can be mounted to the V6) has higher tongue capacity, but the tow capacity weight would be the same.
 If you go to the MAX, your 5 speed will become a 4 speed. Forget about using 5th. It won't happen even at 55 mph. It will CONSTANTLY hunt 4th-5th if you try. Leave it in 4th and accept how it behaves. You will never break any 0-55 mph speed records towing 5000 pounds. It will take a solid 20+ seconds to get to highway speeds when near max tow capacity.
 I know these things because I had a 2003 4runner V6 (4 speed). It did not like a 2013 Starcraft 17RD, and it also did not like the 2013 177 R-Pod. 3rd gear was the norm, MAX speed was 65 mph on the flat at about 3000 rpm...period...Or if trying for 70 mph, wringing the engine out to near 3500-4000 rpm all the time.
 After 12 months of small trailer ownership and about ten 480 mile round trips, I realized I needed better, and stepped up to a diesel. No reasonable comparison between my soft roader VW Touareg TDI and the off road designed 4Runner. I loved my 4Runner (10 years, I bought it new) but it was NOT a good tow vehicle, and it was NOT fuel efficient under any circumstances. No regrets. Even VW dieselgate won't really hurt me. It's sad about the whole dieselgate scandal, but VW deserves an EPA boot up it's ass for the lying.
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 11 Jan 2017 at 6:12pm
I think the 80% rule is pretty reasonable.  When you're at towing capacity you are at the limit of safety.  Some people will argue that the engineers who come up with towing capacity limits throw in an X% tolerance on the high side.  That may be true, but it doesn't count legally if you have an accident.  But aside from that, if you're any kind of intelligent, reasonable person, in my opinion, of course, peace of mind is on an inverse curve to trailer weight compared to towing capacity.  As you close in on reaching the limit or going over it your need to pay attention to every little thing and your anxiety level is going to go way up.
It's the kind of thing I'd do as a one-off, short trip thing, but not as a long term solution.
mjlrpod View Drop Down
Direct Link To This Post Posted: 11 Jan 2017 at 6:38pm
I purched a new t.v. because i felt it might be to dangerous. i had a 3000 pound tow capacity vehicle, and my rp172 weighs 2200 empty. The numbers work if you keep the cargo below 500- 700, doable but i would be maxed out. I purchased a nissan frontier with 6100 tow capacity. Now i will have peace of mind. Like anything, it all doesnt matter till theres a problem. Get in an accident, and be found to be anywhere near tow capacity, and you can count on a serious lawsuit, and or criminal charge, especially if someone gets hurt. so not worth it.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 11 Jan 2017 at 7:17pm
I think 80% is a good figure, hard to put 500-700 pounds of stuff in an R-Pod. I have hoses, filters, some tools, grill, kitchen supplies, bedding and clothes basically. I carry heavy items in bed of truck (coolers, water, more tools). I use truck space to haul the needed items for trip vice the norm stuff I need for TT. Constantly looking at what is in Pod and eliminating the stuff I never used. I like being prepared. I have an extra fresh water hose and a couple of different sewer lines, extension cords. Mostly small light weight stuff. The stuff I don't want to remove after every trip. I try to balance front to rear and side to side, really about common sense.
Direct Link To This Post Posted: 11 Jan 2017 at 7:37pm
Thanks everyone! Very helpful.
Diane and Michael
2007 Toyota Tundra
ronahue View Drop Down
Direct Link To This Post Posted: 11 Jan 2017 at 7:42pm
This URL will take you to an excellent page with a calculator and some explanations of towing capacity.
http://changingears.com/rv-sec-calc-trailer-weight-tt.shtml
Ron & Sharon
2015 R-Pod 179
2022 Nissan Frontier
